Author Topic: 3 Genuine + 1 replica Alloy wheel...is my car safe?  (Read 4311 times)
Offline cal tdi
  • dub or die
Re: 3 Genuine + 1 replica Alloy wheel...is my car safe?
« Reply #15 on: January 16, 2012, 08:57:41 pm »
after making sure its the correct offset id say the 2nd most important thing would be to make sure the rep is balenced correctly as the weight of the rep compared to the proper alloys must differ a bit??
Candy weiß Mk6 GTI - Stage 2
Offline janus909GTI
« Reply #16 on: January 16, 2012, 09:21:33 pm »
just double checked the replica alloy,
ET is engraved onto the rear but there is no number following on afterwards which is pretty useless....
although thinking about it...........
"510618X 7.5J" that number which i listed before, perhaps the 51 at the start refers to the offset??
If the number above is from the rep then off set is et51 wheel size is18x 7.5" wide. By the looks of things you'll be fine running all four
best news ive had all week!!! thanks...
Offline billymac
« Reply #17 on: January 17, 2012, 09:59:38 am »
I don't want to scare anyone as I'm not absolutely sure, but. Do replica wheels not use taper seat bolts (is that not why they come with new bolts) and genuine wheels use a radius seat? Obviously you cannot use one with the other if you want the wheel to stay on!
I was recently offered a set of 3+1 gen/rep and did not go for them for the above reason. Although if it was the case you could use taper seat bolts on the rep and radius on the gens, assuming all other parameters are matching.
Anybody know for sure?
Offline janus909GTI
« Reply #18 on: January 17, 2012, 01:30:08 pm »
i dont see why they would make specific VW replicas which require differing bolts to the originals? doesn't make sense...?
Offline gizmo68
  • We're here for a good time, not a long time
« Reply #19 on: January 17, 2012, 01:57:53 pm »
Because they are making them to their own specs and not VW's therefore they will do whatever is cheapest / more common.
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
Offline janus909GTI
« Reply #20 on: January 17, 2012, 02:44:23 pm »
hmmmmmmmmmmmmm, well is there anyway i can tell by looking at the Alloy??
Or does anyone have any knowledge of this?
Offline billymac
Offline janus909GTI
« Reply #22 on: January 17, 2012, 10:17:41 pm »
well, im having new tyres on all four wheels, balanced and put onto the car tomorrow, so ill let you know how it goes with the OEM bolts already holding on my 17's!
