Author Topic: How to remove the front badge  (Read 1080 times)
Offline N44LED
« on: January 15, 2012, 12:52:25 pm »
hi guys know it sounds silly but dont want to brake anything in the process. as want to spray it satin black.
Aled
Offline Little_Dave
Re: How to remove the front badge
« Reply #1 on: January 15, 2012, 12:56:45 pm »
Aled
Easiest way is to remove the front grill from the car so you can get to the clips at the back of the badge.
Lift the bonnet and remove the 2 torx screw either side of the slam panel and release the 2 clips on the outer edge of the grill, then remove the 2 philips screws from underneath the numberplate plinth in the top of the lower mesh grill and lift the front grill from the car. reverse to put it back on the car  :happy2:
Dave
Offline N44LED
« Reply #2 on: January 15, 2012, 02:03:26 pm »
Thanks Dave going to try this in a min
Offline nathangallo
« Reply #3 on: January 15, 2012, 02:04:50 pm »
Easiest no tools just twist anti clockwise! :happy2:
hugh jass
« Reply #4 on: January 15, 2012, 02:10:32 pm »
 Twisting off the badge is not as easy as it sounds if you get one of the clips caught it might just snap :mad: :mad:(done it)
  As LITTLE_DAVE said :happy2: No swearing and blood loss involved
Offline nathangallo
« Reply #5 on: January 15, 2012, 02:16:37 pm »
ive had three different badges on mine and it was fine, you do have to be careful as they can snap.
i did want to do it the safer way of removing the grill its just i dont know how easy it will go back on  :confused:
Offline N44LED
« Reply #6 on: January 15, 2012, 02:17:12 pm »
thanks hugh
hugh jass
« Reply #7 on: January 15, 2012, 03:31:25 pm »
 "hugh"  :grin: :grin:
Offline Little_Dave
« Reply #8 on: January 15, 2012, 04:39:18 pm »
Mine wouldn't twist or turn at all so did it the safer way and learnt how to remove my grill at the same time if i need to in the future  :wink:
Goes back on really easily nath, just slot the bottom in first by the number plate and then pushthe top edge in and the 2 clips snap into place then just put all 4 screws back in and all done  :happy2:
Dave
