Author Topic: 2 things  (Read 3759 times)
Offline nathangallo
2 things
« on: January 16, 2012, 01:16:14 pm »
But of help guys rear gti and Golf badge how to take off.
Also rear vw boot handle!
Offline gizmo68
  • We're here for a good time, not a long time
Re: 2 things
« Reply #1 on: January 16, 2012, 01:23:40 pm »
Badges use either fishing line or a credit card under them.
For the boot handle you need to remove the interior trim (one screw in each 'handle' and a good pull to release the clips, do not do this in the cold as the trim will be more brittle and will more than likely split).
Once the trim is off there are 3 allen head bolts holding the handle on.
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
Offline ktlstar
Re: 2 things
« Reply #2 on: January 16, 2012, 01:24:16 pm »
Badge, i used a stanley knife/flat blade and prised it off. Very easy!!
Gti badge - use fishing line and go behind it pulling it side to side.
Boot handle - remove inner plastic to get to it. IIRC 3 torx bolts holds it in place.
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Re: 2 things
« Reply #3 on: January 16, 2012, 01:42:22 pm »
can also use dental floss instead of a fishing line
Offline nathangallo
Re: 2 things
« Reply #4 on: January 16, 2012, 02:29:49 pm »
Does the chrom part of the handle split into 2 like the front badge i.e chrome front separates from the back?
Re: 2 things
« Reply #5 on: January 16, 2012, 02:32:41 pm »
It does indeed.
Offline nathangallo
Re: 2 things
« Reply #6 on: January 16, 2012, 03:09:22 pm »
Thanks all  :driver:
Offline nathangallo
Re: 2 things
« Reply #7 on: January 17, 2012, 05:03:36 pm »
Guys just can't get this inside panel off! Tugging pulling all sort, all I want is the chrome part off the badge any ideas?  :signLOL:
Re: 2 things
« Reply #8 on: January 17, 2012, 05:13:26 pm »
Are you talking about the boot interior? Requires brute force and removal tools to help.
Offline nathangallo
Re: 2 things
« Reply #9 on: January 17, 2012, 05:16:02 pm »
Ye mate :smiley:
Removed the two screws in each handle
And I'm just pulling and nothing at all and I'm thinking of if it's this hard to get off god knows what it is like to get back on  :signLOL:
All I want to do is spray the chrome part steel grey to go with my car ! :happy2:
Re: 2 things
« Reply #10 on: January 17, 2012, 05:17:36 pm »
Took me a good 30 mins I think of trying. Had some removal tools to wedge the cover from the boot and worked my way round.
You want to spray the badge. All I wanted to do was insert a straw!
Offline gizmo68
Re: 2 things
« Reply #11 on: January 17, 2012, 05:18:28 pm »
B a good pull to release the clips, do not do this in the cold as the trim will be more brittle and will more than likely split).
You do need to pull it good and hard!! note what I said about the cold though!
Offline nathangallo
Re: 2 things
« Reply #12 on: January 17, 2012, 05:45:09 pm »
Insert a straw :confused:
Ye that's what I am thinking it is cold outside and maybe that is having an influence on it, it just seem impossible lol,
Ill have to give it a go on the weekend when I have more time  :laugh:
Offline gizmo68
Re: 2 things
« Reply #13 on: January 17, 2012, 05:48:28 pm »
The point about the cold is not because it makes it harder to remove, the cold makes the plastic harder (more brittle) so when it flex's (and it WILL) the chances of it splitting are dramatically higher!
Wait until the weather warms up 1st, you can't paint in the cold anyway.
