Author Topic: I'm after a cheap spray wax for my clay bar is this ok at £3.99 posted?  (Read 1985 times)
Offline Mingle
hi as above I'm going clay bar my golf on Saturday and im after a cheap spray wax to use. is this ok?
Follow link
http://item.mobileweb.ebay.co.uk/viewitem?itemId=200701454239&index=2&nav=SEARCH&nid=69634815216
thanks  :happy2:
Offline Tamiyoman
  • -Receive: 39
Sounds cheap to me, if you use Bilt Hamber clay you only need water to use it, helps keep costs down!
This ought to be detailing section?
I am going to clay my car next time I wash it.  Going to use the meguires starter kit
Offline kawakcallum
Dont do it it's £1 at asda
Offline Mingle
Thanks mate ill check that out :)
Why a spray wax and why a very cheap one?
Offline Mingle
It's just when I've done it before I used expensive spray wax and used alot of it and wiped it off once I've clayed the car. then i used the same wax to do the car as I would normally. am I doing it wrong? what's your way?
« Last Edit: January 16, 2012, 09:45:10 pm by Mingle »
Offline Frodo-anni
  • -Receive: 45
If your claying the car then you use a lube with the clay, something like megs last touch. After clay give the car a quick wash. Seal if wanted then wax. Choice down to you.
mk5 GTI Edition 30 DSG No0391
Offline Mingle
I've just been using the spray wax as a lube for the clay, it's the way I was shown by a mate. will check out the lube now tho :)
just got back from asda to and my store does not stock wax been to two :(
think I may just buy from the link as it's still very cheap for a spray wax :)
Makes more sense. You can use a quick detailer spray for lubrication. I prefer using Dodo Juice Born Slippy but also liked Megs Smooth surface clay kit.
Even with Bilt Hamber clay, I use Born Slippy instead of water.
