Author Topic: Tyre wear on inner edge, front and rear.  (Read 3360 times)
Offline Mandy
  • -Given: 95
  • -Receive: 94
« on: January 19, 2012, 10:36:28 am »
I have noticed my tyres are wearing quicker on the inner edges, both front and rear tyres. Eg, on both the rear inner edges they are 5mm, but the centre and outer are 6mm.
What is the cause of this and is it normal, or do I need to get anything adjusted?
Tyres are Vredestein Sessantas and only suspension mod is WALK.
Thanks. :smiley:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Tyre wear on inner edge, front and rear.
« Reply #1 on: January 19, 2012, 10:55:26 am »
Alignment?
Diesel Daily Hack.
Offline Tamiyoman
  • -Receive: 39
« Reply #2 on: January 19, 2012, 11:27:28 am »
Camber adjustment probably needed Mandy?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: January 19, 2012, 11:39:46 am »
Alignment?
X 2  I'd be looking at the Toe   :happy2:
« Reply #4 on: January 19, 2012, 12:27:31 pm »
 :surprised:
What about the suspension? :laugh:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: January 19, 2012, 12:30:27 pm »
 :congrats: :signLOL:
Offline driver rider
  • -Given: 18
« Reply #6 on: January 19, 2012, 01:55:47 pm »
sounds like alignment to me possibly tracking....but as its all grout tyres hope your springs haven't gone??ps what's WALK?
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7 on: January 19, 2012, 03:42:47 pm »
^^^^^^^^^ Whiteline Anti Lift Kit   :happy2:
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #8 on: January 19, 2012, 09:04:22 pm »
Ok, so sounds like I need some sort of alignment check, I guess the proper 4 wheel alignment.
I don't really understand but does it mean I have negative camber if my tyres are wearing ion the insides? :chicken:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #9 on: January 19, 2012, 09:14:39 pm »
Wear on the inner of the tyre would suggest that. Have a look at this thread, might help to locate somewhere to do it:
http://www.mk5golfgti.co.uk/forum/index.php/topic,17704.0.html
Saintsteve
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #11 on: January 19, 2012, 10:09:39 pm »
Thanks for the link, i will have a read...
Just read this somewhere:
Quote
Different driving styles can also influence the desired camber angle as well. An enthusiastic driver who corners faster than a reserved driver will receive more cornering grip and longer tire life from a tire aligned with more negative camber. However with the aggressive negative camber, a reserved driver's lower cornering speeds would cause the inside edges of the tires to wear faster than the outside edges.
Does that mean I need to drive quicker. :driver:
 :signLOL:
  • -Given: 18
« Reply #12 on: January 21, 2012, 08:55:50 pm »
Thank you.  Ill be trawling the forum to see what this kit is all about.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #13 on: January 21, 2012, 09:21:26 pm »
Try here for starters  http://www.mk5golfgti.co.uk/forum/index.php/topic,395.0.html   :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: January 21, 2012, 09:46:30 pm »
Wear on the inner edges isn't due to camber, but the toe being out.  The toe should be set inwards (or positive) slightly.  If its toeing out then the inside edges of the tyre are being dragged along the road.
1mm difference isn't really a worry though and is quite normal even with the tracking being perfect.  I would also make sure the tyre pressures are correct.
Follow AKS tuning on Facebook
