Author Topic: Different Wheel Offset Driver/Passenger Side?  (Read 1066 times)
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« on: January 19, 2012, 11:31:38 am »
I'm looking at replacing my alloys with another set in the next few month (so they'll be up for sale soon) but I needed to know if my new set of alloys would work (offset, tyre size, etc). So last night I went out and measured my current alloys and how much inset there was between the wheel outer rim and the top-most outer part of the arch.
I have OEM Seat BBS Alloys 18 x 7.5" ET 51 so pretty normal (same as GTI 18's) and 225/40/18 Toyo T1R tyres. My car is lowered on Eibach Pro Springs also
These are the results I got, wheel rim to arch:
Driver Front: 19mm
Driver Rear: 21mm
Passenger Front: 15mm
Passenger Rear: 19mm
 :stupid: :stupid:
I can remember somebody observing that the rear axle on a Mk4 golf was 10mm narrower (to counter understeer) so I assumed this was the same with the Mk5. Can anybody tell me what may be wrong with my car?
I haven't had it 4 wheel laser aligned after my lowering springs. Would that solve it?
Thanks in advance for your help/opinion.  :happy2:
« Last Edit: January 19, 2012, 12:54:49 pm by dodds-gttdi »
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Different Wheel Offset Driver/Passenger Side?
« Reply #1 on: January 19, 2012, 11:46:43 am »
Your measuring system will be far too inaccurate to pick up differences in mm
It would be worthwhile getting a 4 wheel alignment
PLANS: Stage 2+
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #2 on: January 19, 2012, 12:35:37 pm »
 :stupid: Have you read the first post? One wheel is majorly out! By 4 or 6 mm!! Plus there is no difference in axle width between front and rear. I thought the rear was 10mm narrower.
This I thought. Anybody used CLCM Alignment in Sighthill, Edinburgh? Any good reports, price estimates?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: January 19, 2012, 12:44:30 pm »
so your steering wheel was 100% bang on straight to within 1mm, you were on ground that has been proven to be perfectly level, you measured at exactly 0 degrees on the wheel on all 4 ocassions, there was absolutely no human error between you and your tape measure?
even if your wheel was bang on straight, which i assume it was, by your own admission you've had a suspension mod without having it aligned, so it's probably going to be out a little anyway.
sorry to sound obnoxious but i stand by my comments. you can't measure this accurately enough for 4  - 6mm to mean anything at all.
« Last Edit: January 19, 2012, 12:47:33 pm by sub39h »
PLANS: Stage 2+
