Author Topic: Finally untethered 4S jailbreak :)  (Read 9453 times)
Offline Betty02
    • iBett
Re: Finally untethered 4S jailbreak :)
« Reply #60 on: January 24, 2012, 02:28:08 pm »
Anyone got a working Siri proxy? Tried hundred the past few weeks and nothing!
http://siri.imzdl.com are doing 1 year reliable ones but didn't really want to pay tbh?
Siri toggle doesn't give the option to add more servers but is good at opening 3rd party apps and turning wifi/3G/bluetooth on off setting percentage screen brightness etc
Think I've confused you Mike!
I use Spire which I was told was the most reliable Siri app out there as OpenSiri has not fully functioned and a few security loop holes! Using Spire it allows you to stick in Siri proxies as they are updated daily and only seam to last a few days max, but I;ve failed to find a working one over the past few days ;)
Hope this helps!
ADMIN NOTICE: Please do not use the site for advertising!
Offline vwrascal
« Reply #61 on: January 24, 2012, 11:08:09 pm »
4s was painless to do, ipad took 3 attempts (kept freezing :scared:) been messing around abit :ashamed:
Offline PDT
  • -Receive: 142
« Reply #62 on: January 25, 2012, 11:34:55 am »
My TV tube sleep doesn't work well, will be ok for the first few times but then refuses to work. If I respring in wintwerboard it will work again maybe 2-3 times.
Anyone else had this issue?
« Reply #63 on: January 25, 2012, 11:43:17 am »
Exactly the same here.  Quite buggy. I haven't used tvtube since ios4 was fine then
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #64 on: January 25, 2012, 11:49:18 am »
For Repos use the ones in this link in addition to the already installed ones
http://jaxov.com/2012/01/top-10-best-cydia-sources-repos-of-2012/
For apps/tweaks i have
Activator - Make your own gestures and hardware button presses launch apps etc
App Sync - for syncing Jailbroken Apps with iTunes
Barrel - Make cool transitions between app screens (recommend curl and roll away)
Color Keyboard - Change the colour of the keyboard
Fake Carrier - Change you carrier name to anything you like. Accepts emoji icons too
Flux - Automatically adjusts the colour temp of the screen at night and in fluorescent lights. Google it
Five Icon Dock - What it says on the tin
Five Column Springboard - What it says on the tin
Folder Enhancer - Folders open and close faster, have unlimited apps in a folder and a folder within a folder
Font Swap - change the font for anything & everything
Lock Info - Same as iOS Notifications but a lot better
HTC Plugin HD for Lock Info - Gives the HTC style clock and weather together on the Lock Screen
Multi Icon Mover - What it says on the tin
Pull to refresh Mail - What it says on the tin
Pull to refresh Safari - What it says on the tin
SBSettings - Allows quick access to common settings (3G, Airplane mode, Bluetooth etc)
SBSettings HD theme - Theme for SBSettings
Serious SBSettings HD - Theme for SBSettings
SiriToggles - Allows you to launch any app, change any setting by voice
Winterboard - For applying theme packs to change App icon's soundsets etc.
Depending on what time i finish work i'll put up some screen shots of various bits :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #65 on: January 25, 2012, 02:46:08 pm »
I cannot get the VW slider or background to work sorry im on 3gs
Offline boxxer1973
« Reply #66 on: January 25, 2012, 02:57:23 pm »
same here
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
« Reply #67 on: January 25, 2012, 03:08:11 pm »
Carl you don't need fake carrier with sbsettings.
You can change courrier in system options of sbsettings  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #68 on: January 25, 2012, 03:48:13 pm »
Thanks Mike never noticed that :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #69 on: January 25, 2012, 04:07:25 pm »
Here are some screen shots.
This is the Lock Info screen. Each of the little tabs is Expandable i've just collapsed them for illustration
This is Folder enhancer. Once you have more than what fits on one screen you get another screen just the same as the normal springboard
Five Icon Dock and Five Icon Springboard. Plus showing Carrier change and font change.
Color Keyboard
Font change in other Apps etc
There is a few other things like the Barrel that you can't get screen shots of but this will give people an idea of the sort of thing Jailbreak allows you to do :happy2:
Offline heavyd
  • -Receive: 29
« Reply #70 on: January 25, 2012, 04:49:44 pm »
Bytafont is also much better than fontswap :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #71 on: January 25, 2012, 05:05:38 pm »
I am a mong :signLOL:
It's Bytafont I'm using  :stupid:
I used to use Fontswap before on my iPhone 4
« Reply #72 on: January 25, 2012, 05:06:45 pm »
Your words noy ours. But fully endorsed by everyone on here.  :P
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #73 on: January 25, 2012, 05:09:06 pm »
At least i admit it though  :P
Offline MarkMarked
« Reply #74 on: January 25, 2012, 07:07:30 pm »
Thats because the images are designed for the retina display of the 4 and 4S.
All the retina images have the @2x part in the image name
If you can browse to the file structure on your iPhone i.e using iphonebrowser on Windows
Browse to \library\Themes\VW Slider.theme\bundles\com.apple.TelephonyUI  (take a look at my post 42)
and put the three atched files in the folder
they should be called
[I can't test this as I don't have 3GS, but they are named correctly and are of the correct size]
« Last Edit: January 25, 2012, 07:32:02 pm by MarkMarked »
