Author Topic: Chattering tailgate  (Read 760 times)
Chris
Chattering tailgate
« on: January 21, 2012, 04:50:47 pm »
Has anyone suffered with a chattering tailgate, mine chatters when i turn the ending off or over these surfaces put down before crossings etc
took the shelf out and its still there but leave the tailgate open and try it and nothing
Offline robby
Re: Chattering tailgate
« Reply #1 on: January 21, 2012, 04:55:18 pm »
Chattering???
Have you tried adjusting the rubber bungs so pull it in closer so it isn't as loose?
Chris
« Reply #2 on: January 21, 2012, 04:57:17 pm »
How do they adjust ?
Offline robby
« Reply #3 on: January 21, 2012, 07:13:21 pm »
I've just sold mine so can't look
The bungs should adjust by turning them - 1 way makes them stick out more and turning them the other way pushes them in
If the tailgate is loose then you'll probably have to have the bungs sitting further out
Chris
« Reply #4 on: January 21, 2012, 07:49:36 pm »
Tailgate doesnt feel lose when shut though so it must be very minor adjustment or something else
Offline TonyZed
« Reply #5 on: January 21, 2012, 10:56:45 pm »
My money is on the rear light lens, the one on the tailgate. If the noise is coming from that area (you may need to get someone into the boot and drive up a bumpy road, I volunteered my wife!) you'll have to take the trim off to get the lenses assembly off.
It's not easy to fix it 'cos it is the inner part of the lens and it's glued together IIRC.
Good luck.
TonyZ
