Author Topic: Not a good day....  (Read 9997 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: Not a good day....
« Reply #15 on: January 21, 2012, 08:34:21 pm »
I have got a set of mk5 R32 front brakes knocking around in the workshop and they are going cheap now the customer have gone to huge AP racing stoppers. :driver:
 They belong to James >  http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=3247  might be worth a PM to crack a deal.. :happy2:
Nick
« Last Edit: January 21, 2012, 08:53:02 pm by R-tech-Nick »
01455 617233
Offline Black9
  • -Given: 35
« Reply #16 on: January 21, 2012, 08:49:03 pm »
If a caliper is stuck on then its usually due to a lip on the disc. Due to them being a windback piston you cant open them up to get the room required to remove the caliper from the disc.
Use a grinder to remove a section of the lip from the disc opposite the caliper, rotate the disc 180 degrees and caliper comes off the disc easily.  This is the stuff they teach you at nvq level 1  :confused:
Good point, couldn't really make out much from the mechanic as his English isn't that great. Will go see them on mon and mention girding the lip off and removing the caliper this way
Is there any other reasons why the caliper would be stuck on?
« Last Edit: January 21, 2012, 08:57:52 pm by Black9 »
Offline alackofspeed
  • -Receive: 24
« Reply #17 on: January 21, 2012, 09:06:57 pm »
If there is a lip, the easiest way is normally to unbolt the caliper from the carrier, slide the caliper off the pads, remove pads and unbolt carrier.
Alternatively maybe the mechanic has left the handbrake on.   :evilgrin:
Offline gazon69
« Reply #18 on: January 21, 2012, 09:17:29 pm »
By the sounds of things personally i would be getting a second opinion
Offline vRSAlex
  • -Receive: 253
« Reply #19 on: January 21, 2012, 09:39:25 pm »
You tend to only find out the caliper is seized when its removed and won't wind back.
It's very easy to rebuild the calipers with a repair kit.
Follow AKS tuning on Facebook
Offline vRSAlex
  • -Receive: 253
« Reply #20 on: January 21, 2012, 09:41:02 pm »
Does he mean the piston is seized or the bolts to the carrier are seized?
Offline Black9
  • -Given: 35
« Reply #21 on: January 21, 2012, 11:57:14 pm »
According to him it's stuck on & won't come off, after seeing a few replies I think I'll go down myself on Monday and get him to have second go with a few of the methods explained in this thread. Appreciate the replies, very helpful. Will repost & let use know the outcome :happy2:
« Reply #22 on: January 22, 2012, 02:05:56 am »
i have had this problem--I clamped the flexi pipe of and opened the  bleed nipple and used the wind back tool to get the piston back
Offline stuartDLK
« Reply #23 on: January 22, 2012, 02:17:30 am »
Happened me as well and my car only had 67k on the clock. Only reason i found out it was seized was because the rear breaks were sticking on when i was breaking.. So i brought mine to the mechanic and he tried the wind back tool but no joy... new caliper was needed....went to the other side to clean the pads and ohhh yessssss that side had decided to seize, so i had to change both back calipers and 2 new sets of pads.. heartbreaking  :sad1:
Offline Black9
  • -Given: 35
« Reply #24 on: January 22, 2012, 03:25:14 am »
But if the calipers seized there's no other way to remove other then bleed calipers?
Dsg steel
« Reply #25 on: January 23, 2012, 02:01:35 pm »
My rears was seized at 55k.
Got a refurbed one from sc motors and it was quite cheap
can't remember how much but a lot cheaper than vw dealer.
