Author Topic: Front Light adjuster  (Read 1119 times)
Offline Syrag64
« on: January 21, 2012, 10:43:30 pm »
The left hand side headlight wont adjust when i use the dial on the dash, is this a common fault?  Is it easily fixed?  I had the front bumper off a couple of weeks ago is there a chance the connector may have come adrift??
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Syrag64
Re: Front Light adjuster
« Reply #1 on: January 22, 2012, 04:52:49 pm »
Had a look at the lighyt today the motor is running but nothing is happening  :surprised:
Can anyone help me please?
Offline Little_Dave
« Reply #2 on: January 22, 2012, 05:40:42 pm »
Was it working ok before you removed the bumper? If not then there's your culprit and you'll need to remove it again and double check the connections  :happy2:
Dave
Offline Syrag64
« Reply #3 on: January 22, 2012, 06:05:07 pm »
Anyone got any pics of the inside of the headlight where the motor sits? Mine seems loose.
