Author Topic: DSG RESET  (Read 2246 times)
Offline Arron84
DSG RESET
« on: January 22, 2012, 07:14:43 pm »
Im new to this scene and tried a search.
id lije to know if doing a dsg reset will help on the initial pull off as mine seems slightly snatchy pulling on or sometimes reversing.
Saintsteve
Re: DSG RESET
« Reply #1 on: January 22, 2012, 07:49:11 pm »
Could be a mechatronics issue  :sick:
is your car around the 57/08 reg?
Offline Arron84
Re: DSG RESET
« Reply #2 on: January 22, 2012, 10:23:43 pm »
Its an 06 gt tdi 170 46000miles
Saintsteve
Re: DSG RESET
« Reply #3 on: January 23, 2012, 07:17:03 am »
Your symptoms do sound like the Mechantronics has a problem, but it's worth trying a reset as you have nothing to loose..
Offline pjh1999
Re: DSG RESET
« Reply #4 on: January 24, 2012, 10:53:39 am »
Hi,
Sorry to jump but I am having the same problem with my 08 model.
What is the Mechantronics that you said could be gone and what does it do?
Is it an expensive fix?
Offline Tamiyoman
  • -Receive: 39
Re: DSG RESET
« Reply #5 on: January 24, 2012, 10:57:32 am »
Mechatronics, control gear changes in the DSG box, its basically all the actuators that open and close clutch plates, if they are at fault you can get jerky gearchanges and if failed loss of drive, VERY expensive to fix  :scared: unless you can get VW to sort it
Offline pjh1999
Re: DSG RESET
« Reply #6 on: January 24, 2012, 12:25:22 pm »
Ok Thanks TAMIYOMAN for the explanation.
I will try the reset first and keep my fingers crossed.
Offline Arron84
Re: DSG RESET
« Reply #7 on: January 26, 2012, 10:30:45 am »
mine only seems to somtimes have a jerky pull off when going from stand still on the brake and comming off and straight on to the accelorator. is it me going from brake to accelorator to quickly? all other gear changes are smoothe as far as i am aware
cheers
Offline SRC
  • -Receive: 27
Re: DSG RESET
« Reply #8 on: January 26, 2012, 02:10:41 pm »
Torque through the gearbox - drive - is reduced when your foot is on the brake pedal.  If you come off the brake and onto the accelerator too fast, you rush the smooth take up.  Try holding the car on the handbrake and you'll feel much more of a pull.  Personally, I think VAG should have included torque reduction on the handbrake, too.  There's a knack to being smooth when lifting off the footbrake and applying throttle, but it soon becomes second nature.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline Arron84
Re: DSG RESET
« Reply #9 on: January 31, 2012, 11:20:28 am »
yeah the other day i was in the car facing up hill and when i went from brake to throttle it jerked bigtime, but yesterday i did use the hand brake and it helped loads mate. i have a black code map on mine, would having a map on the car make the take off any different?
