Author Topic: K03 Stage 3 question  (Read 2524 times)
Offline 56OctyVRS
  • -Receive: 72
« on: January 22, 2012, 08:33:53 pm »
Is an intake required to go stage 3?  I have one fitted but would like to go back to the OE engine cover purely for the quietness. I have fitted the Autotech HPFP internals and will be having a BCS exhaust fitted next month so have all the bits for stage 3.  I know that VWR Racing dont use an intake on stage 3 in order to improve the mid range power rather than peak power. I also know the K04 Gtis run 300bhp with a simple remap and that with the same engine cover.
Offline RENNTAG
  • Premium Performance Parts
Re: K03 Stage 3 question
« Reply #1 on: January 22, 2012, 09:09:51 pm »
Isnt stage 3 an upgrade to the KO4 turbo. Or do you mean stage 2+
« Reply #2 on: January 22, 2012, 09:11:05 pm »
Whose stage 3 are you talking about??
Offline 56OctyVRS
  • -Receive: 72
« Reply #3 on: January 22, 2012, 09:19:15 pm »
Sorry. Shark Performance call stage 2+ stage 3.
« Reply #4 on: January 22, 2012, 09:23:31 pm »
fwiw I used to run revo stage 2+ with an itg drop in air filter and made very healthy numbers on the dyno.
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: January 22, 2012, 10:17:59 pm »
The main improvement with dumping the oem airbox is a slight gain in boost throughout the rev range and the turbo doesn't have to work as hard.
Follow AKS tuning on Facebook
Offline martziniuk
« Reply #6 on: January 23, 2012, 12:53:24 pm »
I just run with an OE panel filter at stage 2+, there isn't much difference in performance as I rarely go high rpm.
« Reply #7 on: January 23, 2012, 01:23:33 pm »
You'll see how good the k03 actually is in the low rpm range once you go k04...  :smiley:
Offline james
« Reply #8 on: January 23, 2012, 01:49:09 pm »
na my k04 is far better at low rpm to the k03.
Offline martziniuk
« Reply #9 on: January 23, 2012, 11:34:17 pm »
I would expect to see spool up time take a little longer with the k04 as its a larger turbo but hopefully no too long  :driver:
