Author Topic: Hidden trick to going low on static?  (Read 3602 times)
Offline SL03 JOE
« on: January 22, 2012, 11:55:25 pm »
Hi there, I'm just wondering wether there is a way to go real low on a static drop that doesn't rub the front tyres out when turning?
I have the KW V3 set up and I'm wondering how I could adjust the front to stop rubbing some times and go lower and how to drop the back more?
Thanks, Joe.
2006, silver, 5 door, top spec, low miles MKV GTI for sale - looking for offers above 9k!
Joe.
Re: Hidden trick to going low on static?
« Reply #1 on: January 23, 2012, 01:07:57 am »
You've got kw v3 and you want to go really low?? You bought the wrong coilovers.
Offline SL03 JOE
« Reply #2 on: January 23, 2012, 06:46:07 am »
I'm looking to go lower but not silly low!
I know the KW V3 do go pretty low, but on lowest they can rub on when turning under power. I've been thinking front camber to hopefully stop this?
Joe.
Joe.
Offline brady88
« Reply #3 on: January 23, 2012, 10:52:08 am »
Rolled arches...but would cost a bomb!
Camber and some extremely stretched tyres  :grin:
Offline SL03 JOE
« Reply #4 on: January 28, 2012, 01:00:16 pm »
well rears are factory rolled and been quoted £100 for front from www.archenemy.co.uk and they come out to you and do it all for the same price.
Joe.
Joe.
Offline brady88
« Reply #5 on: January 28, 2012, 01:52:20 pm »
Joe.
£100 seems a very reasonable price...well worth it  :happy2:
But if the paint cracks, which it normally does, then it's a re-spray on both wings  :sad1:
« Reply #6 on: January 28, 2012, 07:11:56 pm »
There is nothing to roll on the front arches, about 2 or 3 mil.  :chicken:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: January 29, 2012, 09:00:34 am »
Have you done the arch liner screw mod? Mine never rubbed on my r32 and it was very low
Diesel Daily Hack.
Offline big al
« Reply #8 on: January 29, 2012, 01:32:52 pm »
Be careful rolling the front arches as the roller can pull the metal and spoil the line where the front panel meets the front door.
Speak to Greg Howells, he charges £60 per arch and rolls it without using an arch roller. Though as said you will probably have to spray the panels again.
Failing that there are H&R ultralows that Si Sweetland sells, wider arches and stretched tyres to prevent rubbing,
Offline SL03 JOE
« Reply #9 on: February 01, 2012, 07:02:24 pm »
yeah well i think im going to be flaring all the archs soon and do it properly and get spaces to make it sit right.
but can't decide between Rotiform Nue or 3SDM  :confused:
joe.
Joe.
