Author Topic: GT TDI [04] suspension.  (Read 2656 times)
Offline AjayB
  • Golf GT TDI
« on: January 23, 2012, 12:10:59 am »
Hi guys..
Am i correct in saying that the GTI and the GT TDI are the same ride height.. 15mm Lower than standard? Or is the GT TDI not as much as the GTI? Ive got 35mm H&R's and i'm thinking about going back to standard on my GT TDI as the springs i have aren't really for the GT's.. only for the standard golfs.
Mines a 2004 GT TDI btw.
Any help would be appreciated.
« Last Edit: January 26, 2012, 04:11:18 pm by AjayB »
Build: http://www.mk5golfgti.co.uk/forum/index.php/topic,40699.0.html
Golf MK5 GT TDI | 35mm H&R Springs | Silver Cabon Fibre Inlays | 20% Rear Tints | Backbox Delete- Dual Tips | GTI Rear Valance
To Do: RNS/RCD510 | FBSW | Black BBS CH 18"
Offline Trekmeister
  • Golf GT 140
Re: GTI and GT TDI suspension?
« Reply #1 on: January 23, 2012, 01:41:04 pm »
I think not all GT's have the same ride height, I am under the impression the GT sport has the 15mm lowered ride height whereas the GT is higher. I could be wqrong? My 2006 GT sits quite high with  17" alloys. I am going to drop mine by 20mm (Eibach sportslines)  which should give the look I am after.
« Last Edit: January 23, 2012, 01:44:03 pm by Trekmeister »
Offline AjayB
  • Golf GT TDI
« Reply #2 on: January 24, 2012, 02:11:45 am »
Thanks for the reply.. i was under the impression that all the GT's had a lower stance.. might just leave my 35mm in until i can get a good replacement set then  :rolleye:
Offline sandancer
« Reply #3 on: January 24, 2012, 07:05:09 am »
The 2.0 tdi's had sports suspension with a 15mm drop over standard, not sure if it's the same set up as the GTI though. The diesel is a heavier lump so I'm pretty sure it will different over the petrol models
Offline AjayB
  • Golf GT TDI
Re: GT TDI [04] suspension.
« Reply #4 on: January 26, 2012, 04:12:05 pm »
Does anyone know if I should go for Eibach Pro or Sportlines?
Offline daboy3000
  • MKV GT TDi
« Reply #5 on: January 26, 2012, 04:17:13 pm »
I would change the shocks too, mine bottoms out over bumpy roads at speeds, I have Sportlines
Offline Trekmeister
  • Golf GT 140
« Reply #6 on: January 26, 2012, 05:13:12 pm »
What drop are you running yours on?
Offline daboy3000
  • MKV GT TDi
« Reply #7 on: January 26, 2012, 05:16:49 pm »
35-40mm I think
