Author Topic: Dual Zone Climate HELP!?  (Read 1836 times)
Offline Simpy
« on: January 25, 2012, 10:09:04 am »
My car has the dual zone climate in it. As my car never came with a handbook just the service book, ive never known fully or understood how to work it properly!? As long as i could get hot air out of it i was fine, summer just had the windows down. But whilst i was getting it serviced i had the air con regassed. Now i know this is a stupid question but howd you get the air con on? as there is no specific button as there is in other cars!? Is it just a case of turning the dial down untill it reads LO?! Which of the directional buttons needs to be iluminated? Do the vents need to be open? Also Econ and Auto what are these two buttons for?! Ive had it on LO after having it on fully hi for a while and it was cold........but not freezing cold as i expected?!
Re: Dual Zone Climate HELP!?
« Reply #1 on: January 25, 2012, 10:12:08 am »
turn the dails both to Lo and that should activate the air con
Offline Simpy
« Reply #2 on: January 25, 2012, 10:16:01 am »
Nothing else needs to be switched on or the vents open?  :stupid:
« Reply #3 on: January 25, 2012, 10:28:32 am »
all depends where you want the air!!open the dash vents,select the button on the dash and away you go
Offline Simpy
« Reply #4 on: January 25, 2012, 10:40:49 am »
So basically all im doing is turning my heater control to cold?  :stupid: Wheres the A/C Part of that? You can put heaters on cold in any car!  :confused:
« Reply #5 on: January 25, 2012, 10:46:32 am »
thing the lower part are cold,when you get to the lo position the air con should be really cold :signLOL:
Offline Matto
  • -Receive: 116
« Reply #6 on: January 25, 2012, 01:20:13 pm »
On the right hand dial do you have Auto and Econ?
Offline mb
  • -Receive: 29
« Reply #7 on: January 25, 2012, 04:08:10 pm »
If auto is lit then the climate control will keep the temperature at whatever you have the dials set to using heat/air con. If econ is lit then the aircon is switched off
Offline Matto
  • -Receive: 116
« Reply #8 on: January 25, 2012, 04:15:26 pm »
Was going to put as above too. As a side note to this, the compressor turns off anyway of the outside air temp is 4 degrees or lower.
Offline SRC
  • -Receive: 27
« Reply #9 on: January 26, 2012, 10:32:03 am »
Auto is a fully automatic climate control setting.  If you want your car teamperature at, say, 18 degrees then the climate control will get it there and keep it there.  If AC is needed to do that, then it will cut in.  If not, it won't.
Econ keeps the AC off, so it may not bring the temperature down enough in warmer weather.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline john87
  • -Receive: 53
« Reply #10 on: January 27, 2012, 10:07:08 am »
On the later mk5's (on my 2008 model anyway) there is a specific A/C button which you can switch on/off in the logical fashion.. the earlier models had the ECON button, which works in the opposite way (when the light is on, A/C is off)
