Author Topic: RNS510 Rev C  (Read 1308 times)
Offline ktlstar
RNS510 Rev C
« on: January 25, 2012, 05:46:16 pm »
Does this look okay ? Would i need anything else regarding the battery drain i see pop up now and then ?. My car is a 57 plate if that helps
http://www.ebay.co.uk/itm/270900317699?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649#ht_997wt_1270
Thanks.. :laugh:
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline mvb12
  • -Receive: 64
Re: RNS510 Rev C
« Reply #1 on: January 26, 2012, 08:39:58 am »
from what i've read it effects pre 2007 models, but you will need to check what CAN gateway your currenlty running.
check out this link and hope it helps.
http://www.my-gti.com/2296
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: RNS510 Rev C
« Reply #2 on: January 26, 2012, 09:07:02 am »
I would be highly surprised if a 57 plate car suffers from battery drain. Unless you have a car that has been sat around on a dockyard somewhere for over 12 months.
I haven't seen a car earlier than June 2007 with lower than an L revision gateway (but that doesn't mean they don't exist) which is fine. I had a March 2007 car with a K revison gateway and that was fine too. However it is hit and miss with K revsions.
Yours will have an L revision at the least if not an S revision so you should be ok :happy2:
Offline ktlstar
Re: RNS510 Rev C
« Reply #3 on: January 26, 2012, 09:36:19 am »
Thank you guys....  :D
Offline ktlstar
Re: RNS510 Rev C
« Reply #4 on: January 31, 2012, 12:03:08 pm »
Right so the rns510 is fitted, however i found out i got a K can gateway.
What happens now lol ? I believe i will get battery drain ?
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 160707F2001031
   Coding: 3F0F034007000001
   Shop #: WSC 01279 785 00200
   VCID: 2F67386DBE066DB
radio software : 2720
« Last Edit: January 31, 2012, 12:14:05 pm by ktlstar »
Offline ktlstar
Re: RNS510 Rev C
« Reply #5 on: January 31, 2012, 12:09:49 pm »
Everything is working such as MFSW, MFD display, sat nav etcetc . Well chuffed with it.
Offline DaveR77
    • UK-MKIVS.net
Re: RNS510 Rev C
« Reply #6 on: February 03, 2012, 12:22:08 pm »
If the VW logo appears each time you turn it on it should be fine, my Jan 07 K gateway was ok
Offline mvb12
  • -Receive: 64
Re: RNS510 Rev C
« Reply #7 on: February 03, 2012, 12:28:13 pm »
if you do have an issue with battery drain from my understanding you can downgrade the firmware.
My RNS510 is version B (purchased from Madlil a few weeks back  :happy2:). My firmware is not the latest but it does what i need it to do.
Offline ktlstar
Re: RNS510 Rev C
« Reply #8 on: February 03, 2012, 12:30:16 pm »
Seems fine so far- no issue with battery drain.
