Author Topic: Lets talk hybrids  (Read 6719 times)
Offline vRSAlex
  • -Receive: 253
Re: Lets talk hybrids
« Reply #30 on: January 28, 2012, 05:54:51 pm »
I have a K04 hybrid on the vRS.  Check out the build thread for more info.  :happy2:
Alex have you had it on the dyno yet?
Not yet.  The nearest dyno dynamics rr is miles away and I've not had 5 mins spare.
Follow AKS tuning on Facebook
Offline Russ_leeds
« Reply #31 on: January 28, 2012, 05:59:28 pm »
yeah the link is working today, but it wouldnt the other day  :stupid:
So what can the k03 internals handle safely? Is it pushing them too hard with the k04 upgrade?
cheers
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline vRSAlex
  • -Receive: 253
« Reply #32 on: January 28, 2012, 07:36:00 pm »
cheers
Well I think you are right on the limit with a k04 bolted to a k03s engined car.  Plenty of cars are fine though and it all depends on how hard you push it.
They seem to be able to handle around the 350 bhp mark ok, but its that one boost spike that will bend a rod, and you don't always know its bent until the engine gets pulled apart.  Still drives ok with a slightly bent rod.  If it bends too much then the oil jet snaps off and causes a fair amount of damage.
Offline Russ_leeds
« Reply #33 on: January 28, 2012, 09:52:59 pm »
so roughly how much would it cost to have stronger conrods and pistons?
cheers for the info its something i want to do, working up to stage 2+ at the min, nearly there with the supporting mods then when its mapped  :driver:
Offline vRSAlex
  • -Receive: 253
« Reply #34 on: January 28, 2012, 11:39:33 pm »
Pistons are fine.  Good for well over 400bhp.
Rods are around £300 plus the fitting cost of around 2 days labour.
Also factor in big end bearings, head gasket, ARP head studs, head skim, inlet valve and port strip and clean and some coolant  :happy2:
Offline TT-Turbo
« Reply #35 on: January 29, 2012, 10:41:19 am »
Was just thinking about the whole K03 hybrid and why can't you change internals and machine various parts of the housing for them to fit? If you can refurb the turbo (which you can) then why can't you change them to something else?
« Reply #36 on: January 29, 2012, 10:43:46 am »
You can hybridize a k03 as I know a guy in Austria who has done it. Didn't ask where he had it done though.
Offline gazon69
« Reply #37 on: January 29, 2012, 11:02:49 am »
The ko3 turbo can not be hybrid according to Turbo dynamics and turbo techniks. They said the internals on the ko3 are forged and they couldnt supply suitable parts to make a hybrid.
so how come these guys are saying this?
Offline TT-Turbo
« Reply #38 on: January 29, 2012, 12:11:29 pm »
That's what I was thinking.
Maybe since they said "suitable parts" as a replacement maybe it's a fitment issue as the K03 housing is smaller. Not sure but if someone has done a hybrid k03 then that's proof in the pudding really!
Offline yin
  • -Given: 77
« Reply #39 on: January 29, 2012, 12:41:46 pm »
This is a ko3 rod pushed to 400bhp levels :scared:
Offline vRSAlex
  • -Receive: 253
« Reply #40 on: January 29, 2012, 01:21:12 pm »
The k03 manifold is also much skinnier than the k04 mani.
The only k03 hybrid that I have seen was made by ABT for the xbow.  It used the k04 mani, chra, and the k03 compressor housing.  They called it a 300bhp kit but it always made 260!
Cost vs power wise its best to go straight to a k04.
Offline gazon69
« Reply #41 on: January 31, 2012, 01:58:28 pm »
How did they only manage to get that sort of power. That was with no other mods surely. If so i reckon thats pretty impressive taking into account the gti runs 200hp. With other mods like exhaust, intake, hpfp it would surely be well over 300hp, shouldn't it
Offline nezquick
« Reply #42 on: January 31, 2012, 02:21:17 pm »
After more research Im starting to agree with your last comment. k04 is probably the best route.. although it is always going to be a bit of an attention seeker at shows if you say "mine has a hybrid k03/04" especially when people don't know what that is..
