Author Topic: offset questions?? plz help.  (Read 2697 times)
Offline kingjeb
« on: January 27, 2012, 12:21:25 pm »
I'm looking into getting some landrover Mondials that are ET54 and have 16mm adaptors on the front and 20mm on the rear. Will they still fit as my car is dropped on Eibach Sportlines? and help would be greatly appreciated.
Offline gazbutS3
Re: offset questions?? plz help.
« Reply #1 on: January 27, 2012, 03:02:31 pm »
what width are the wheels?
Offline kingjeb
« Reply #2 on: January 27, 2012, 08:00:48 pm »
8 inches.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: January 28, 2012, 05:52:52 am »
yes you should be fine
PLANS: Stage 2+
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: January 28, 2012, 05:53:05 am »
« Last Edit: January 30, 2012, 09:50:26 pm by sub39h »
PLANS: Stage 2+
Offline vRS_Pagey
  • -Receive: 59
« Reply #5 on: January 29, 2012, 08:36:22 pm »
When you say adaptors, do you mean spacers?
Offline Yawn
« Reply #6 on: January 31, 2012, 08:14:01 pm »
Probably adaptors as PCD will be different
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #7 on: February 01, 2012, 02:02:39 am »
ET54 - 16 = ET38
No chance to fit a 8.0" ET38 wheel on a Mk.V without pulling fenders.
"You get what you pay for."
Offline vRS_Pagey
  • -Receive: 59
« Reply #8 on: February 01, 2012, 09:21:08 am »
If it was the PCD, why would it be different sizes front and rear though?
ET54 - 16 = ET38
Really?  That size should only sit 19mm further out.  :confused:
« Last Edit: February 01, 2012, 09:24:21 am by vRS_Pagey »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #9 on: February 01, 2012, 09:38:37 am »
Really. Even 225s on a 8x18 ET45 may rub under certain conditions.
ET40 will rub. ET38 will rub.  :wink:
Offline stu_no_1
« Reply #10 on: February 01, 2012, 09:45:08 am »
I have et 32 on the rear and they rubbed with a 225 I've had to drop down to a 215 tyres and the front I dropped down to a 215 and got 5mm shaved off the back of the wheel so et 37 on front with 215 I have no rubbing even with a full car my wheels are 8.5j dunno if this info helps I'm running lowtec springs which are a bit lower at the front than eibach sport lines and my arches are standard apart from doing the screw mod at the front
Offline vRS_Pagey
  • -Receive: 59
« Reply #11 on: February 01, 2012, 10:20:11 am »
I have 18 x 8J ET45 on lowered suspension and they have never rubbed, even with the boot full of stuff and 200kg of family members in the car, admittedly that is in my vRS but........ :drinking:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #12 on: February 01, 2012, 01:16:16 pm »
Well, on rear it's possible to run lower ETs of course if you have enough camber adjusted.
I have -1°10' on all four wheels. So no need for lower ETs on rear.
Or you might not be fast enough.  :wink:
I run 8x19 ET45 with 225/35 and 8x18 ET44 with 225/40 on a coilover.
I know several people runnung simmilar combinations.
It's very close.
So I can not recommend ET37 both front and rear to anyone.
