Author Topic: Advice ( mk5 gt tdi 140)  (Read 15508 times)
Offline joeya
Re: Advice ( mk5 gt tdi 140)
« Reply #15 on: January 28, 2012, 07:20:51 pm »
I've got a '54 plate 140hp tdi (remapped to 185hp) currently at 109k miles it feels better then most cars I've driven, friends comment on how good it drives. Quick enough to keep up with most things.
Great cars just watch out for abused ones and the issues with rust!!
Offline Trekmeister
  • Golf GT 140
Re: Re: Re: Advice ( mk5 gt tdi 140)
« Reply #16 on: January 28, 2012, 07:24:06 pm »
had mine done by r-tech,it was a excellent map...I say was because i had a lot of trouble with oil pressure building up and blowing turbo's
Was that a direct result of map, what gains were you running at?
Sent from my GT-I9100 using Tapatalk
« Reply #17 on: January 28, 2012, 07:28:58 pm »
no the problem was already thier--i had the turbo replaced then went to see Nick about the map,but the turbo went again because the engine breather was blocked even thou it was brand new--
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #18 on: January 30, 2012, 04:41:11 pm »
Was it the breather in the end?  I knew it...lol :happy2:
IMO remapping the 2004-06 TDI 140pd hit and miss, not with the software but with the hardware.   Stock boost is 1.35bar and just by going to 1.45bar boost some turbos have a hissy fit.   In a lot of cases on spec1 maps on older 140PD I will give the car 50millbar more boost and use the fuel to make the power ans run a little smokey.
IMO if your unsure how good your turbo is or worried its on then list deemed to fail,  then dont cause your self worry or hardship dont get it mapped.... but saying that they fail just as much in stock form................. so buy a TFSI :signLOL:
My VNT TDI findings
 http://www.golfgtiforum.co.uk/index.php?topic=184800.0
01455 617233
Offline Trekmeister
  • Golf GT 140
« Reply #19 on: January 30, 2012, 05:05:45 pm »
Did you change turbo and clutch before or after remap?
Offline RSam84
« Reply #20 on: January 30, 2012, 06:29:49 pm »
My brothers tdi 140bhp shat its turbo on 24k mileage and his is a 58 plate cost him about a grand to fix it all in the end, his is running an awsome gti remap
Offline Trekmeister
  • Golf GT 140
« Reply #21 on: January 30, 2012, 06:56:25 pm »
My VNT TDI findings
Its not so much the turbo actually going, I could live with that if it just "packed up" its the actual destruction to engine parts what worries me. Would seem a new turbo is the way forward for peace of mind!
« Last Edit: January 30, 2012, 07:27:27 pm by Trekmeister »
Offline vRS_Pagey
  • -Receive: 59
« Reply #22 on: January 30, 2012, 07:56:23 pm »
For a couple of hundred quid more he could have gone for a hybrid...... :sick:
Offline smokey
    • Club night in Bristol - Drama
« Reply #23 on: January 30, 2012, 08:03:18 pm »
I recently got a 2004 GT TDI 140 and love it. Getting 46mpg average (this is calculated via fuelly as the computer on the VW exaggerates abit (55mpg), which can be sorted through VCDS) and 520miles out of a tank of V Power Diesel.
Not remaped it yet, but its on my list.
Talking about the weaker turbos on the earlier models TDI's. I had my turbo changed when i bought it. The car had done 80K and the old turbo was loud and the car apparently went into limp mode a few times, so the garage i bought the car from put a brand new one in.
Will this still be like the weaker turbos, will this one be better?
2004 GT TDI 2.0 (140bhp) - Mods so far - GTI pedals, GTI Interior Metal Strips, GTI Metal Ashtray, Gear Knob with metal surround, TPMS (with switch), RNS-510, Skoda bluetooth kit, Armrest MDI, VCDS owner (Bristol)
« Reply #24 on: January 30, 2012, 08:45:48 pm »
The turbo that went was brand new,but it wasn't the map that caused them to it was a build up of oil pressure and as the breathing system was blocked it decided to chuck the oil out through the turbo,I was going to and still will put a hybrid turbo on probs a dark side development one,when i know my engine is running right
Offline R-tech-Nick
  • -Receive: 30
« Reply #25 on: January 31, 2012, 03:20:20 pm »
[/quote]
[/quote]
If the engine sucks up oil from the inlet side when the turbo fails you can bend rods or have the engine rev until the crank falls out.
01455 617233
Offline gti-ted
« Reply #26 on: January 31, 2012, 04:05:23 pm »
The 140 are better than the 170 and more reliable to remap etc.
Only if you don't own a 170!  :laugh:
Or a mapped one pushing 220 bhp with a DPF delete  :P
Offline smokey
« Reply #27 on: January 31, 2012, 04:35:22 pm »
Ah ok, i thought it was due to the type of turbo they used on the earlier cars. I was hoping that becuase mine has just been changed (4000 miles old) i thought it might have been replaced with a newer better one and they might have stopped making the weaker older ones??
