Author Topic: CAR magazine Feb 2012 - Buying a MK5 GTi  (Read 6992 times)
Offline Mk5 GTian
  • -Receive: 37
« on: January 29, 2012, 06:57:47 am »
I've just read the used hot hatch article in February's CAR. They have consulted Jabbasport and VAGTECH to comment on buying a used MK5 GTI. I'm sure there is nothing here that you guys don't already know about, but I thought it would be worth posting for those who are about to buy, or have recently bought a MK5 GTI. there are at least 2 additional things I have learnt that I'm getting checked at my cars major service on thursday. Main points are as follows:
1) The OEM turbo dump valve has a rubber diaphragm which can split, and lead to a loss of that turbocharger surge of power delivery at 2000rpm. Jabbasport replace this with a plastic piston from the S3, but if you are sticking with OEM, get it checked at service. DOES ANYONE KNOW IF THIS DIAPHRAGM CAN BE REPLACED ON ITS OWN?
2) More serious is the fuel pump follower, which is prone to early wear and tear, especially if the car has been on long-life servicing. GET THIS  CHECKED IF YOUR VEHICLE IS 40,000 MILES PLUS, AS FAILURE CAN RESULT  IN SERIOUS TOP-END DAMAGE. Jabbasport usually change them every 20,000 miles as a precaution, as they are only 28 quid a pop.
3) If the car is a DSG and lurches when you pull away, it's likely to be a failure of the Mechatronic ECU. Should be super-smooth when you pull away.
4) As it's direct injection, fuel goes straight into the cylinder, so therefore the back of the valves can get coked up leading to high oil consumption. However, VW says loss of 1Litre per 1k miles is normal, so check oil level regularly.
5) Check the inner wear on the rear tyres. The outsides can look fine, but the inner edge can be down to the canvas if the rear shocks are weakened. You should hear a droning noise similar to a shot wheel bearing if this has happened.
6) And finally, CAR recommend swerving the DSG and going for a basic spec with cloth seats and manual  for one of  the best hot hatches ever made!
« Last Edit: January 29, 2012, 07:07:08 am by Mk5 GTian »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: CAR magazine Feb 2012 - Buying a MK5 GTi
« Reply #1 on: January 29, 2012, 07:24:40 am »
Nothing new  there, that info is all over this forum  :wink:
Over the top mod list ;o)
diesel junior
« Reply #2 on: January 29, 2012, 07:26:26 am »
Thanks for that ian, anyone any idea of the etka number for the fuel pump follower since my spanish doesn't stretch to that.....will be easier to head to the stealers in benidorm armed with the number!
Offline edd666999
  • -Receive: 89
« Reply #3 on: January 29, 2012, 07:32:02 am »
06D 109 309 C
Offline Mk5 GTian
  • -Receive: 37
« Reply #4 on: January 29, 2012, 07:32:41 am »
As I said in the thread, I'm sure there is nothing new in this for you guys, but it's really useful for people like me who have just bought one, or are about to buy one, as it pulls all these things to look out for together. It's not directed at the experts like yourself Danish, but those of us who are new to ownership. For example, I didint even know a fuel pump follower existed, but now I know to get it checked and probably replaced.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: January 29, 2012, 07:41:02 am »
generally the cam follower is a problem in the US where they use poorer quality fuel. that's why it's not so heard of here. that's not to say mine isn't being replaced next month when it gets serviced. they have been known to fail here too, but it's being replaced more as a precaution than genuine worry. be interested to see it's condition tho and it will be changed every service once i've gone Stage 2+
« Last Edit: January 29, 2012, 07:44:37 am by sub39h »
PLANS: Stage 2+
Offline Mk5 GTian
  • -Receive: 37
« Reply #6 on: January 29, 2012, 08:04:51 am »
 Thanks for that, I can find no evidence of this being changed previously, so as I'm over 80k, I think it's a good idea to get it  changed, if only for peace of mind. I'll ask my garage to keep the old one and get some pics up. It would certainly be useful to see how it's worn on a car which has been serviced yearly.
  • -Given: 243
  • -Receive: 154
« Reply #7 on: January 29, 2012, 08:12:44 am »
I'll post a link to my tread, where you'll see a cam follower that at the time of change had done 160.000km, surface should be all black due to the DLC  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,7823.msg121569.html#msg121569
diesel junior
« Reply #8 on: January 29, 2012, 10:02:31 am »
And a very useful post for those of us that live abroad and can't get Car magazine half the time, shame as it's very good.....
« Reply #9 on: January 29, 2012, 10:03:45 am »
Actually it would appear to be related to the type of oil used...
Offline Mk5 GTian
  • -Receive: 37
« Reply #10 on: January 29, 2012, 01:25:32 pm »
Does anyone know about the dump valve rubber diaphragm? If this is split, is it a case of simply replacing the rubber?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #11 on: January 29, 2012, 01:28:20 pm »
no VW released a replacement DV, called the "revision D" DV. my specialist has quoted me £85 fitted incl. VAT. probably not necessary unless you're planning to remap, but again for peace of mind might as well do it.
PLANS: Stage 2+
Offline Mk5 GTian
  • -Receive: 37
« Reply #12 on: January 29, 2012, 01:41:10 pm »
Thanks for that, Have you seen whatthe faceof the cam follower looks like if it's worn thhrough? Is it missing completely?
Offline Mk5 GTian
  • -Receive: 37
« Reply #13 on: January 29, 2012, 01:44:30 pm »
Thanks for that, can you see the rubber diaphragm to know if it's split, or is it internal within the dump valve?
  • -Given: 243
  • -Receive: 154
« Reply #14 on: January 29, 2012, 01:46:05 pm »
You mean the cam right?  :wink:
It's in fine shape as it's the revision B dual metal cam, not the Revision A  mono metal cam.
Besides i have a Cupra engine in my GTI now wup wup  :driver:
