Author Topic: fitting HID`s  (Read 2219 times)
Offline webby888
fitting HID`s
« on: January 29, 2012, 12:17:40 pm »
i have purchased a HID kit for my gti but i cant seem to work out how to wire them up, iv looked around to how to guides but cant find one that is detailled enough for me to follow
anyone got a guide that i can follow?
thanks
Offline dub singh
  • Snakebite Chasers...
Re: fitting HID`s
« Reply #1 on: January 29, 2012, 03:15:29 pm »
Should be simple plug and play iirc.. Well mine were anyway, no wiring needed
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Offline vRS_Pagey
  • -Receive: 59
Re: fitting HID`s
« Reply #2 on: January 29, 2012, 08:27:28 pm »
+1, if they require wiring I think I would steer clear!  :surprised:
Offline Phil Miller
  • -Given: 86
Re: fitting HID`s
« Reply #3 on: January 29, 2012, 09:26:12 pm »
when i got my set about 2 yrs ago i had to connect the wires to the bulb holders, as the standard bulb holder is connected to the bulb (if that makes sense) i had to cut the plug off that connects to the car loom and then solder on 2 lucar connectors to plug on to the bulb holders
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: fitting HID`s
« Reply #4 on: January 29, 2012, 09:38:25 pm »
Remember they'll have to be removed for the MOT or you'll get an advisory (or a straight fail after Mar 31st).
Offline Phil Miller
  • -Given: 86
Re: fitting HID`s
« Reply #5 on: January 29, 2012, 09:40:27 pm »
as a tester i dont see my HIDs as being a problem  :grin: :innocent:, altho mine has headlight washers, i have been thinking about adding the height adjusters to keep it 100% legal although the wiring could be a PITA
Offline simonp
  • -Receive: 38
Re: fitting HID`s
« Reply #6 on: January 29, 2012, 09:42:36 pm »
Well you're not doing your job properly then, are you?
Offline Phil Miller
  • -Given: 86
Re: fitting HID`s
« Reply #7 on: January 29, 2012, 09:49:13 pm »
LOL nope but then i could do what everyone else will do and thats take the HID bulbs out fit standard bulbs do test, then refit HID bulbs, the only way this can be enforced is if the police pull EVERY car with HIDS and give them a fine, one strike and your out, if they pull you again they take the car, its not right but im sure anyone with HIDs will do the above, so all the new test Laws are doing is making someone spend 5 mins before and after swapping bulbs, ive had my HIDs 2 yrs and i set them up at work spot on, ive had my OH follow me in my car and they dont dazzel, and i dont think ive been flashed yet, dont get me wrong there are some that do dazzel, most of that is down to adjustment/ K of bulbs used
Offline vRS_Pagey
  • -Receive: 59
