Author Topic: GTI international 2012  (Read 106227 times)
Offline Jussa
  • Bicester
Re: GTI international 2012
« Reply #510 on: June 28, 2012, 11:23:30 pm »
bugger wanted to get in the 4's for 0-60, managed a 5.02, how close?  :smiley:
and 13.216, don't spose its too bad for a manual S3 with big fat wheels and a clumsy oaf behind the wheel  :laugh:
Great times Gaz for a manual  :happy2:
I wanted to get in the 3's  :signLOL: got a 4.02, same boat as you  :evilgrin:
Maybe next time without hurricane Katrina!!!!
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #511 on: June 28, 2012, 11:43:17 pm »
Im disappointed with my times, I got 12 seconds last year at stage 1....my Sunday times isn't bad tho  :happy2: it was my 2nd run on the Sundayand I had 6 left so was annoyed when the strip closed but it's for the best, car is still on stock suspension and mounts with 3mm of treadon the front so not bad given the circumstances but im still not happy, should be hitting low 12's :mad:
www.distinctdetailing.co.uk
Offline Little_Dave
« Reply #512 on: June 28, 2012, 11:44:42 pm »
Quite happy with 11th in class with a 6.34 & 14.567  :pomppomp:
Defo could've got closer to 6sec's with a bit more practice and maybe sub 14 but for my first time it was ok  :driver:
Just glad my car is running as it should and as fast as it should be given the mods and stage its at  :drinking:
Dave
« Reply #513 on: June 28, 2012, 11:59:03 pm »
12 second 1/4 with a stage 1 ED30 DSG? :confused:  Do you mean low 13's?
Offline Sunglasses Ron
« Reply #514 on: June 29, 2012, 09:06:54 am »
My thoughts exactly John...  :confused: :surprised: You sure you got 12's last year Jack, don't remember that? Not very often you see a FWD Mk5 in the 12's at Inters and never at Stage 1?!?!
If you are chasing low 12's from a Stage 2+ ED30 you are going to need to get use to being disappointed pal. The only way that will happen is if you strip the whole car and run very sticky drag radials.. There aren't even that many ED30's that have got in the 12's, so that is an achievement in itself mate.. Most are on track tyres and weight loss, but it can be done on stock suspension, full interior and stock rubber, just be prepared to practise.... A LOT.  :laugh: :signLOL:
« Reply #515 on: June 29, 2012, 09:11:21 am »
You're getting there Gaz..  :pomppomp: At least you know that the car is running well as you have pretty much done a carbon copy of my mate's times (the human dustbin who camped with us the other year if you remember?  :signLOL:). He is also running a pre-FL S2+ manual S3 and got 5.0, 5.1, 5.1 & 13.2, 13.1, 13.1 from his 3 runs on Sat..
His biggest problem is his SMF that won't allow him to be too quick on the stick..  :sad1:
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #516 on: June 29, 2012, 11:00:59 am »
Im pretty sure it was 12's....but if your saying that then maybe it wasn't.....I'll try and find last years results
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #517 on: June 29, 2012, 11:03:24 am »
I wasn't to far out this year, traction is the issue, more mods to come for next year so here's my guarantee....I bet you a drink I'll get 12's next year  :laugh:
« Reply #518 on: June 29, 2012, 11:22:09 am »
Get yourself to Pod Jack, it's seen as a lot more accurate and official and you don't have to wait a year  :party:
I'd be up for a meet at some point and I know there's a few others on here who would..  :happy2:
Quote
The trick I found is to run lower boost settings, higher timing and get into 2nd as quick as possible.. If you are Stage 2+ and DSG you don't necessarily need more power mate.
If you crank up the volume on this vid, you can hear me change to 2nd not long after getting off the line.
« Last Edit: June 29, 2012, 11:32:27 am by Sunglasses Ron »
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #519 on: June 29, 2012, 12:48:07 pm »
Did you know you can set off in second on a dsg car  :wink:
Offline RENNTAG
  • Premium Performance Parts
« Reply #520 on: June 29, 2012, 12:53:29 pm »
Do tell?
« Reply #521 on: June 29, 2012, 01:04:59 pm »
I didn't to be honest  :confused: Not sure whether that would work too well on the 1/4 though as you would need to dial in some revs initially to get you off the line fairly quick. Something I doubt would be possible with a 2nd gear launch...
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #522 on: June 29, 2012, 01:13:41 pm »
It's pretty clever how it works.....it's a test plan used to check the clutch plates for vibrations etc and faults being the box has 2 clutches, how healthy it is on the car I don't know....even on a manual I think your burn the clutch pretty quick setting of in second,
I can't fully remember how it's done but if memory serves me correct you put the car in reverse and then D and then Reverse and then select manual and select second, it may be right it may not but it is a combination of that type, I don't work for VW any more so can't check  :fighting:
Offline RENNTAG
« Reply #523 on: June 29, 2012, 01:18:55 pm »
Think i might have to give this a go tomorrow. see if its any good for pulling away when grip is limited lol
Offline gazbutS3
« Reply #524 on: June 29, 2012, 02:57:11 pm »
Yes I remember the big fella, was a great weekend that :drinking:
wonder if I'd have got into the 4's with the TD's on  :smiley:
