Author Topic: BWA 370bhp+ What is needed?  (Read 12231 times)
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: BWA 370bhp+ What is needed?
« Reply #15 on: January 31, 2012, 07:10:49 pm »
The R-Tech lads have a K04 equipped BWA pushing out 370bhp - they recon the engine does it no problems!
374bhp with WMI   :wink:
Could you post the pre and post WMI dyno graphs?
WMI makes no power on its own merits it need to be mapped in to get nice gains , its used for efficiency to run a leaner AFR, strong advance tables and higher substained boost.
01455 617233
Offline R-tech-Nick
  • -Receive: 30
« Reply #16 on: January 31, 2012, 07:14:55 pm »
Nick, whats the fitting cost for water meth on a ed30 ? I will supply the kit, but what do you recommend ?
It not what we do, with James mk5 I was helping him out so we could get some mapping R&D time on the dyno with WMI.
18/19psi to the red @134bar rail pressure with WMI 18-21deg advance is the way forward.....  :driver:    It would be if I can get rid of this stupid EPC fault.... :ashamed:
01455 617233
  • -Receive: 453
« Reply #17 on: January 31, 2012, 07:56:26 pm »
I meant an overlay graph from when you originally mapped the k04 to results after wmi installed.   :smiley:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #18 on: January 31, 2012, 08:08:56 pm »
i have got a mk5 GTI with a BWA(with ko4) engine.      I brought a S3 ecu from ebay as i was going to install a BHZ engine.
I wentt down the local scrappy and they offerd me this engine for 1.4k with gearbox but with no loom or ecu.
The engine was from a Golf R20
can i use my BWA loom?
I can't see why not, I have an BWJ (Cupra engine) with AXX loom and AXX ECU.  :happy2:
Over the top mod list ;o)
Offline james
« Reply #19 on: January 31, 2012, 08:12:37 pm »
You still running the GTI map sensor then? 1.5Bar limit?   as when i put the S3 map sensor in i just get fault codes.
  • -Given: 243
  • -Receive: 155
« Reply #20 on: January 31, 2012, 08:24:46 pm »
I have the Cupra/S3 sensor but not fitted yet, but i assume it won't work unless i find a Golf R ECU or ED30 ECU for my car  :sad1:
Offline james
« Reply #21 on: January 31, 2012, 09:20:33 pm »
s3 ecu should be fine mate
Offline vRSAlex
  • -Receive: 253
« Reply #22 on: January 31, 2012, 09:27:45 pm »
You can use the old loom fine.  The engine is physically the same.
Just use the old map sensor.  The s3 map sensor may need scaling to get it to work properly.
I can get 21mm wrist pinned forged rods for the s3/ed30 engine now too.
Follow AKS tuning on Facebook
Offline james
« Reply #23 on: January 31, 2012, 09:52:11 pm »
The CDL has the 21mm wrist pins all ready does it not?
Offline vRSAlex
  • -Receive: 253
« Reply #24 on: January 31, 2012, 10:38:28 pm »
Yep, but not forged h beams  :happy2:
  • -Given: 243
  • -Receive: 155
« Reply #25 on: February 01, 2012, 05:06:53 am »
You digged up some Alex, where did you find them if i may ask??  :drinking:
