Author Topic: Rattle on part throttle 2.0TFSI - Maybe resolved....  (Read 9572 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=jn7vfjgqd15a49gcr9ldguq7hk&/topic,19740.0.html
« on: February 02, 2012, 01:38:48 am »
Hello good people.
I've noticed that my car has developed a strange rattle on part throttle. Sounds a bit like a paper clip shaken in a bottle, fairly quiet. If I'm doing 70 let's say in gear 5 and go 50% throttle I can hear it, but as soon as I go WOT the noise disappears.
Now, no change in the cars performance. It still goes like stink, and pulls without any flat spots on tailing off it high rpm.
Cam follower being changed as a precaution as its 43k old.
Could it be DV or the N75 boost regulator valve making the noise?
Any thoughts? (apart from driving everywhere on WOT :-))) )
Ta
Rich
« Last Edit: July 23, 2012, 11:30:10 am by richwig83 »
Re: Rattle on part throttle 2.0TFSI
« Reply #1 on: February 02, 2012, 12:41:15 pm »
Morning nudge.
« Reply #2 on: February 02, 2012, 06:02:09 pm »
Did everyone hit the ignore button!
LOL.
Saintsteve
« Reply #3 on: February 02, 2012, 06:11:36 pm »
 :laugh:
How you can hear a paper clip rattling sound at 70mph is beyond me!.. i suggest WOT :laugh:
Are you running a stock exhaust/ Loose Baffle perhaps?
« Reply #4 on: February 02, 2012, 07:08:29 pm »
Stock everything engine related, bar the revo map.  Definitely coming from engine bay. :-/
Offline Beddie
  • -Receive: 76
« Reply #5 on: February 02, 2012, 07:12:52 pm »
Is there a heat shield on the rear engine bay bulkhead on the 2.0t?
Reason being is that i had the same kind of noise on the van, turned out to be the heatshield had detached and was resonating at certain revs / speed, drove me mental!  :laugh:
Carbon Grey Edition 35 - Here
« Reply #6 on: February 02, 2012, 07:24:52 pm »
Thanks beddie will look at that tomorrow. I just hope it's not the turbo.
« Reply #7 on: February 02, 2012, 07:40:57 pm »
Might be the wastegate but really we are only speculating Rich.
Best get someone who knows what they are doing to look at it.  :wink:
Offline blackmagic
« Reply #8 on: February 10, 2012, 12:39:27 am »
Have you got anywhere with this fella. Reason is I have a similar sound coming from engine bay as well as you said just seems to be mid throttle / revs. I can only describe as a metal tinkling sound.
I have fuel pump so thought might be cam follower but inspected and replaced old one was reasonable condition. New has made no difference sound still there.
I'll prob pop down my specialist but if you fix let us know as may be same thing and I'll do same.
Black GTI K03 Revo Stage 2+,
« Reply #9 on: February 13, 2012, 10:42:50 am »
Not had chance to let anyone have a look at it yet. Sound like we have the same noise from your description. I also had the cam follower changed as a precaution, and didnt help the noise.
Rich
Offline muckipup
  • -Receive: 25
« Reply #10 on: February 13, 2012, 03:36:02 pm »
Crikey - could be anything Rich - if you have the engine cover, have you checked the mounts or taken the cover off and given it a shake (also gives the chance to look around the engine bay a bit more and wiggle stuff  :wink:), what about something in the air vents/pollen filter area? Can you hear it mid-revs in neutral with the bonnet open (near cam belt/water pump)? Only heard in gear and only 5th gear (gearbox/bearing related)?
« Reply #11 on: February 13, 2012, 06:00:19 pm »
I think its in most gears but more so the top 3. If it were gearbox/bearing/mechanical, why would rattle stop on full throttle.
Weird!  :stupid:
Saintsteve
« Reply #12 on: February 13, 2012, 06:09:46 pm »
Something sounds like its resonating, exhaust dowpipe ..around the cat, loose baffle perhaps
« Reply #13 on: July 02, 2012, 11:41:07 pm »
Still rattling...  :sad1:
Offline Moz
« Reply #14 on: July 03, 2012, 10:39:49 am »
Don't suppose it's anything like this?
