Author Topic: Improving aerodynamics with aftermarket parts  (Read 50271 times)
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
"You get what you pay for."
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: Improving aerodynamics with aftermarket parts
« Reply #62 on: September 18, 2012, 03:26:37 pm »
Interesting option:
fitted my cupspoiler  :evilgrin:
I know - he's not the only one.  :wink:
But - does it fit to the Golf ???
« Last Edit: September 18, 2012, 03:29:40 pm by the bruce »
Offline Tamiyoman
  • -Receive: 39
« Reply #63 on: September 18, 2012, 05:46:35 pm »
Thanking You!!  :drinking:
Now where can I get one!? (if not too expensive). I don't really need one but I don't really need some of my other mods either.
ON their sit it gives prices
FRP wing tip £47
Carbon Tip £282
« Reply #64 on: September 18, 2012, 05:50:36 pm »
I don't know why I'm thanking you, Miles! (I hope it is Miles and not Myles)
I don't want to spend £282 on a small bit of carbon just for styling.
Offline Tamiyoman
  • -Receive: 39
« Reply #65 on: September 19, 2012, 10:16:23 am »
Same goes, If I wont spend money on brakes I am not likely to be spending money on a wing tip  :signLOL:
It is Myles btw  :grin: :grin:
« Reply #66 on: September 19, 2012, 03:42:16 pm »
....I can remember that: It's Myles as in Tamiyoman  :happy2:
Offline fuscobal
  • -Receive: 27
« Reply #67 on: October 20, 2012, 05:52:02 pm »
Ok, my wing is here and I sent it for custom mounting it on the car. Follow up on my thread in a few minutes !
Mk5 GTI 6MT - Revo stage 3
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #68 on: October 21, 2012, 02:12:33 am »
Time for some updates. Took the car from my mechanic abouth 1 month ago and it's working fine, except for the same rough idle who seems to never go away. There's some sort of a cyclic noise at idle and don't know why but while on the road the car behaves normally. Didn't have the change to WOT it yet but will do it after installing the wing....wich reminds me of the second update :)
The custom Reverie wing came and it's very well manufactured. After talking to Reverie guys, they advised me to go for the smaller 150mm profile instead of the 225mm one. They said it should be enough for a FWD car and that a larger one would ruin the balance of the car unless I also have a large splitter in front. The wing was made with a span of 1300mm and a 515mm distance between the drop tabs. After speaking to the guy designing the mounts, he said we can't use the car's hinges of the trunk lid so I've distanced the tabs 50mm from the hinges on each side. Didn't weigh the wing yet but it seems to be about 7-800grams only !!!
Uploaded with ImageShack.us
By interpolating between 1245 si 1400mm, at an AOA of 10deg, we get about 43kg@100mph. From an older post over here, the wind tunnel says the OEM GTI has -2kg on front si -37kg on rear @ 200kmh. Those values mean the car has lift at high speeds(but then again most street car have lift). Knowing I'm lowered about 1'' and I have the VWR front air-dam, the real values on my car might be a little better, say +5kg on front and -30kg on rear. In order to compare the downforce brought by the wing and the values we have for the OEM car, we need to calculate the wing's value @  200kmh. 43kg*(200kmh2/160kmh^2)^ = 67kg . So, at 200kmh, the car should have about 0 to 5kg of downforce on front and 30-35kg on rear (67-30 = 37 but I'm considering less because the wing's data has been acquired under freestream and not disturbed air like on the car) !
PS : For those wanting to compare the downforce level of a track-prepped street car and an F1 car, at 200kmh I would have about 1450kg and 40kg of downforce (2.8% of the car's mass) and a formula 1 car would have about 700kg and 1400kg of downforce (200% of the car's mass !!!). I think it's easy to understand how an F1 car can generate such tremendous downforce levels, knowing that the downforce does not generate inertia !
 :happy2: :happy2:
Can't resist to add that to this topic.  :wink:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Offline fuscobal
  • -Receive: 27
« Reply #70 on: October 22, 2012, 09:58:41 am »
The flat bottom is very interesting but way too expensive !
« Reply #71 on: October 22, 2012, 11:11:11 am »
Is that fitted on top of their Summit-Racing braces?
Summit have totally missed the structural 'X' factor advantages which the UNIbrace UB has. Personally I would far rather have the added stiffness of a UNIbrace than this aerodynamic 'improvement' which anyway doesn't convince me as being worthwhile on a Golf.
Offline fuscobal
  • -Receive: 27
« Reply #72 on: October 22, 2012, 11:28:14 am »
It's worth Robin but only if you want to extract the last bit of performance on the car and probably if you also add a diffuser !
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #73 on: October 22, 2012, 08:44:13 pm »
From what I see that car also has a Unibrace fitted.
« Reply #74 on: October 22, 2012, 08:53:06 pm »
....Are you sure? Wouldn't they have fitted their own Summit cross braces?
