Author Topic: ESP fault? VCDS stuff attached  (Read 10582 times)
Offline Scott_GT_TDI
« on: February 02, 2012, 05:30:45 pm »
Hi guys, I hope someone can help me / put my mind at rest.
I bought my 56 plate GT TDI 170 just under a month ago and the warranty from the supplying garage is about to run out. I also purchased a 2 year 3rd party warranty but would prefer to use the supplying garage first if I need to.
I just got my VCDS lead today from Gendan and had a wee shot of it this afternoon with the following results :-
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Thursday,02,February,2012,15:28:21:58566
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 77 7D
VIN: WVWZZZ1KZ7B035856   Mileage: 67530km/41961miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DF    HW: 03G 906 018 DF
   Component: R4 2.0l PPD1.2      4345
   Revision: --H22---    Serial number: VWZ7Z0F7057297
   Coding: 0000072
   Shop #: WSC 00792 210 91867
   VCID: 6CDDEB044F90D63
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 00046 412 16384
   VCID: 73EFF07812AE09B
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
            012 - Electrical Fault in Circuit
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 FH
   Component: Climatic PQ35   120 0606
   Shop #: WSC 00000 000 00000
   VCID: 6FE7FC087E862DB
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004288789
   Coding: E5890F2700041500001400001400000000087F075C
   Shop #: WSC 00046 000 81920
   VCID: 2B5F28188A1E11B
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 070706 020  0501
   Coding: 00038805
   Shop #: WSC 00046
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     110706 014  1201
   Coding: 00208933
   Shop #: WSC 00046
1 Fault Found:
00988 - Lamp for Brake Light; Right (M10)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 66577 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.05 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0LRVGF
   Coding: 0013112
   VCID: 3D7B1640646A8FB
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 035 0070
   Coding: 0000012
   Shop #: WSC 00046 412 172032
   VCID: 74EDF36417A00E3
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 963 B    HW: 1K0 920 963 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F7057297
   Coding: 0003403
   Shop #: WSC 68022 476 96534
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 310010670980D9
   Coding: 3D3F4BC007000003
   Shop #: WSC 00815 210 06574
   VCID: 2C5D2B048F10163
2 Faults Found:
00381 - Databus Instrument Cluster
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 12
00469 - Infotainment Databus in Single Wire Operation
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 65642 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:47:09
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0964
   Coding: 0000692
   Shop #: WSC 00046 412 303104
   VCID: 387507544B48AA3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 356B0E605C5A57B
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 019002005103087F2D04840570085FC690FCA0
   Shop #: WSC 00046 412 237568
   VCID: 830F20B8C20EB9B
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000692
   VCID: 397302507042B3B
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1K0 035 186 R    HW: 1K0 035 186 R
   Component: Radio FO3       021 0014
   Revision: 00021000    Serial number: VWZ7Z2F0022115
   Coding: 0042402
   Shop #: WSC 00815 815 58926
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0912
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
Address 69: Trailer        Labels: 8P0-907-383.lbl
   Part No SW: 8P0 907 383     HW: 8P0 907 383
   Component: ANHAENGERELEKTR H01 0010
   Coding: 0000001
   VCID: F6E9496C81DC9C3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 E    HW: 3C0 035 729
   Component: Telefon             6009
   Revision: 00009000    Serial number: 0000000796162
   Coding: 0016123
   VCID: 254BDE20ECFA27B
1 Fault Found:
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 3
                    Fault Frequency: 0
                    Reset counter: 0
                    Mileage: 1048575 km
                    Time Indication: 1
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D5B2600B40A1FB
End   ---------------------------------------------------------------------
Now, I have NO ESP warning light on the dashboard but it is showing a fault on vcds
What is going on? is it a historical fault that has already been fixed but not cleared? The ESP light does not come on when I press the ESP button near the ashtray, nor does any kind of button illumination happen.
Also any other help with the other faults would be cool if you can.
Thanks in advance,
Scott
Nasir
Re: ESP fault? VCDS stuff attached
« Reply #1 on: February 02, 2012, 05:49:22 pm »
Do the 'ABS' and 'ESP' symbols light up when you start the car? They should, and they go off after a few seconds. Then when you try to turn the car on, the lights come back on and go off when the car has started.
If they don't light up, it sounds like you've been sold a car with a dodgy ABS pump.
« Reply #2 on: February 02, 2012, 06:07:45 pm »
Is that the most likely thing? Surely if its faulty then some sort of light should come on on the instruments?
I'm worrying that this is going to cost a packet :(
Offline Phil Miller
  • -Given: 86
« Reply #3 on: February 02, 2012, 06:36:35 pm »
Now i dont want to worry you but i know of car dealers who remove the cluster and use black silicon on and around the ABS or ESP or ECU light so even tho its lite up you cant see it because its full of silicon
« Reply #4 on: February 02, 2012, 06:51:16 pm »
Well when I was messing about with VCDS in the abs section and went onto the wheel speed sensor bit to check they were all working, the abs light came on whilst I was in that module so I guess that hasnt happened, the dealership I bought it from has an incredibly good reputation so I cant see that happening, fingers crossed. Should the ESP button light up when I press it?
Offline Phil Miller
  • -Given: 86
« Reply #5 on: February 02, 2012, 06:57:59 pm »
Right when you turn the ign key on the ESP and ABS should light up, when started they should both go off, when you press the ESP button the word ESP OFF will light up on the button and the ESP light will come on on the cluster, as your ABS light comes on when you go in to the ABS that should be fine
At no point did i say the garage you got the car from has done it (if it has been done) anyone could have done it, and the mileage on the car is good, im prob wrong but ive come across this loads of times over the years
« Reply #6 on: February 02, 2012, 07:21:22 pm »
Right, the ABS light comes on and goes out, but the ESP light does not come on at all. I am struggling to find any similar issues using the search facility on here.
Offline Phil Miller
  • -Given: 86
« Reply #7 on: February 02, 2012, 07:36:51 pm »
normally if there is a fault with the ESP the light will be on all the time, yours not coming on at all is a bit of a worry, what happens when you press the ESP button? if you try can you spin the wheels? if you can spin the wheels then your ESP isnt working as it should be, try doing this and then again after pressing the esp button
about a yr ago i somehow managed to put my ESP in to a program mode, the light was on all the time and the button didnt do anything, i finished the re programming and the light went out, now it could be the ABS is spot on and the esp is at fault, if you wanna find out take your dash out take the back off it and see if the ESP hole is full of silicon, would make sense TBH
« Reply #8 on: February 02, 2012, 07:50:12 pm »
I can deffinately spin my wheels, thats what made me concerned about a possible problem.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: February 02, 2012, 07:59:40 pm »
You have a faulty ABS pump, someone has tinkered to hide it.
Cluster and Key coding
Location Great Yarmouth
« Reply #10 on: February 02, 2012, 08:09:01 pm »
Is that 100% certain Eddie? as I do not want to go in with my size 12's on to then look like an idiot lol. Any ideas on what I should say to them? If this is the case, then I am going to be incredibly annoyed  :mad:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: February 02, 2012, 09:38:22 pm »
try to Clear the fault, if you can't or it comes straight back.
Go and see them, there obviously is a fault in the system
Offline gillm
« Reply #12 on: February 02, 2012, 09:44:26 pm »
g201 is a dead pump . been there done that
west tuned gt28 @ 340hp
Offline gillm
« Reply #13 on: February 02, 2012, 09:46:25 pm »
and i have a spare pm me if needed
« Reply #14 on: February 02, 2012, 10:33:59 pm »
Gillm, did you have to pay yourself? was it expensive?
