Author Topic: Bigger Battery & Alternator!!!!  (Read 6048 times)
Offline golfman
  • -Given: 17
« on: February 04, 2012, 06:18:50 pm »
Guys i was wondering what would happen if i were to put a stronger battery and alternator on the car?
is there any chance of fire or anything else happening?
the reason I'm asking is because i have added so many extras to my car and it struggles to almost start!!!
any help would be great
cheers
scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline Gti_Mad
Re: Bigger Battery & Alternator!!!!
« Reply #1 on: February 04, 2012, 06:32:18 pm »
i cant see that causing a problem at all scott
all u need is an alternator wiv heavier amperage output and battery
Offline dub singh
  • Snakebite Chasers...
« Reply #2 on: February 04, 2012, 09:22:34 pm »
Im running a 2500W RMS sound system... on a standard alt that came on the 1.6FSI.. between 70-90a i would assume..
Running a BIG Deep cycle battery in the back (Stinger SPV70) supported by a 200a stinger relay...
your alt should be fine, could try just upgrading your Battery and the Big 3 first..?
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #3 on: February 04, 2012, 09:24:45 pm »
That scenario would probably just indicate the need for a higher capacity battery.  Alternators usually have a good deal of headroom in them these days.
What is the spec of your current battery?  Ie, what 'Ah' and what 'CCA'?
  • -Given: 88
  • -Receive: 95
« Reply #4 on: February 04, 2012, 09:25:53 pm »
Why?????
Alternators don't 'start' an engine, the battery does! :nerd:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #5 on: February 04, 2012, 10:38:28 pm »
No prob to fit a bigger battery.  :wink:
But I'd ask two different questions instead:
1. Why change battery or even generator?
2. If changing the battery, why bigger and not better?
Most TDI and TFSI already have a 140 A generator. These are proper sized.
My GTI had the same battery size as most TDI: 70/72 Ah. This sufficient as well.
If you need more capacity for hifi I'd go for a second batt in the boot, if you
need more cranking amps I'd have a look for a more advanced AGM type.
« Last Edit: February 04, 2012, 10:43:52 pm by the bruce »
"You get what you pay for."
  • -Given: 88
  • -Receive: 95
« Reply #6 on: February 05, 2012, 01:22:23 am »
Didn't I say that earlier?  :P
72Ah are very different from 70Ah - the differences in the 'Cold Cranking Amps' (CCA) is very noticeable.
And many TDIs have 80Ah batts.  :wink:
AGMs are still very expensive - a quality calcium or calcium/silver battery with a healthy-sized CCA is probably more than adequate for curing sluggish cranking.
The other advice we missed is better battery 'management' - ie, dont sit in your car for 20 minutes after turning off the engine with the hi-fi cranking out!
« Last Edit: February 05, 2012, 01:25:00 am by Teutonic_Tamer »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #7 on: February 05, 2012, 01:38:46 am »
Yes, you did. I'm with you.
And many TDIs have 80Ah batts.  :wink:.
Possibly.
Many cars come with AGMs from factory, eg all Audi TT (sic), all BMW 1 series, most BMW 3 series . . .
They are used when the battery is not placed in the engine bay.
These are only 20,-- - 30,-- pounds more than a conventinal battery. Of course there are more
expensive racing types (which are small but strong) and the lead/calscium VW uses in the Golf
are pretty good as well.
And yes, don't listen radio without engine running - at least not in the winter !!
« Last Edit: February 05, 2012, 02:11:30 am by the bruce »
Offline dub singh
« Reply #8 on: February 05, 2012, 01:45:09 am »
Unless you have a second battery in the boot  :P
Offline golfman
  • -Given: 17
« Reply #9 on: February 05, 2012, 04:05:50 pm »
Here is my battery!!!!
scott :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #10 on: February 05, 2012, 04:18:23 pm »
That's been my stock battery:
Offline golfman
  • -Given: 17
« Reply #11 on: February 05, 2012, 05:41:31 pm »
Guys the reason that I'm thinking about this is because of all the extra mods that i have added to my car i just think that all the extra lights and power are taking more juice from the battery!!!!!
I'm sure that the vw phaeton has to get a full battery charge when its in for a service just because of all the extra toys it has too
scott :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: February 05, 2012, 06:18:35 pm »
your mods are only going to drain the battery when the engine is not running
Cluster and Key coding
Location Great Yarmouth
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #13 on: February 05, 2012, 06:44:51 pm »
A larger batt doesn't improve anything unless listening radio after engine stop
is possible for a longer period.
If there's more drop you need a larger generator to charge the battery faster.
This is from theory.
In real I guess you didn't need anything at all. Just drive enough to charge the
battery completely.
  • -Given: 88
  • -Receive: 95
« Reply #14 on: February 05, 2012, 08:01:28 pm »
scott :happy2:
That is the good one - 640A SAE Cold Cranking Amps !  :happy2: :happy2:
