Author Topic: RCD 500  (Read 2784 times)
oldtomo
RCD 500
« on: April 26, 2009, 08:17:45 pm »
Hi all,
Can anyone tell me how i can pop off the front off my RCD 500?
Do i need to just lever it out?
Cheers  :smiley:
Offline 182_blue
  • -Receive: 54
Re: RCD 500
« Reply #1 on: April 26, 2009, 08:21:22 pm »
pop the front off ?, what are you trying to do, and is it in the car
Offline x5pea
Re: RCD 500
« Reply #2 on: April 26, 2009, 08:39:46 pm »
if its the plastic surround your talking about.....you need to remove the grill on top of the dash first (just need to try and get a grip off it and pull upwards towards the roof. then theres 2 screws at the top IIRC, u then just need to ease it off, there are 4 brittle clips that run just under the heater controls you prob wanna ease them off with a flat screwdriver.
oldtomo
Re: RCD 500
« Reply #3 on: April 26, 2009, 08:53:17 pm »
Sorry 182 - should have explained myself! I am going to replace it with another headunit and was just curious as to how i get the thing out of my dash board!
oldtomo
Re: RCD 500
« Reply #4 on: April 26, 2009, 08:53:44 pm »
Cheers mate - appreciate the info  :happy2:
Offline 182_blue
  • -Receive: 54
Re: RCD 500
« Reply #5 on: April 26, 2009, 08:59:48 pm »
ahh i see, you need to remove the top vent as said above, although you should remove the bit in at the back of the top vent (sensor) first, then you need to remove the mesh vent  ( using trim tools) and theres only one screw, use this guide (ignore the first bit about the bluetooth) http://www.golfgtiforum.co.uk/index.php?topic=40928.0
oldtomo
Re: RCD 500
« Reply #6 on: April 26, 2009, 09:11:26 pm »
Great guide! Thanks for pointing it out to me!  :happy2:
