Ok, so as some of you saw last year december I tried a cluster swap with a cheater Vag K+Can Commander 1.4.
Let's just say it was a disaster? It never worked so I reverted back to original cluster with following few issue's.
ESP,ABS,Power Steering, Steering Assist, not working.
Since I worked thru the Ross-tech suggestions for recalibrating the G85 and G200/G201 sensor. Which would not work at all btw.
I some how managed to get TPMS (only basic, Tire pressure only system) into what appears to be a output test function.
VW over here in NZ, managed to reset all the settings but the TPMS. So now I have it constantly flashing on the Dash,
It's getting pretty annoying now. If I go into ABS and remove TPMS from coding, ABS simply keeps flashing and never goes away.
f I re-enable the TPMS coding, ABS flashes about 8-12 times then goes away. However TPMS keeps flashing.
If you try and do a new default setting from the Button. The TPMS on clusters lights up solidly and will not go out. As soon as I let go of the button it merely starts flashing again.
I have scanned the whole car and it has no error codes anywhere on any of the controllers.
So If anyone maybe able to help or point me in a direction I can likely try and follow this would be a great help.
