Author Topic: valeo led - blown bulb?  (Read 2570 times)
Offline lukejenks101
« on: February 07, 2012, 05:16:41 pm »
2 of the Led's for my indicators have blown by the looks of things, the tail light works fine but when the indicators go there are 2 out. Has anyone had this before and is it an easy fix?
Re: valeo led - blown bulb?
« Reply #1 on: February 11, 2012, 06:16:17 pm »
bump, this isn't a permanent problem and the connection is fine
Offline cmdrfire
    • Commander Fire - my blog
« Reply #2 on: February 12, 2012, 01:22:29 pm »
No easy way to replace a failed LED apart from dismantling the light unit, desoldering the original LEDs and replacing with the right LEDs...
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #3 on: February 12, 2012, 05:06:12 pm »
I have exactly the same thing! I managed to temporarily "fix" mine by taking it off the car and fully drying the inner out. I cleaned up the electrical contacts with some sandpaper and ACF50 and it worked. I suspect water is getting in from the seal around the light that meets the bodywork.
I only get this in very cold weather by the way. :rolleye:
« Reply #4 on: February 13, 2012, 08:22:26 am »
I have been gettin gcondensation in the same unit, i will give it a go
Offline bodger00
  • -Receive: 20
« Reply #5 on: February 15, 2012, 06:26:35 pm »
Did you have any luck? Another thought is to put some silica gel in the lens.....
Offline Weston
« Reply #6 on: March 08, 2012, 12:13:54 am »
Noticed 2 on mine didn't flash orange when locking the car tonight. Unlocked and locked it lots of times and basically sometimes they flashed, other times they didn't. Quite a few times they did flash but missed the start of the flash by a tiny amount. Bit annoying but probably a damp issue, they are next to each other towards the bottom on the passenger side.
GTI going...
Offline Jaywoo-GTI
  • -Given: 38
« Reply #7 on: March 08, 2012, 10:39:56 am »
I have seen this happening on Mk5 Jettas recently to, Possibly a dry joint problem, Should be a easy fix if it is.
Offline Weston
« Reply #8 on: March 08, 2012, 01:00:21 pm »
What would that involve?
GTI going...
Offline Action jackson
« Reply #9 on: March 08, 2012, 01:14:17 pm »
not enough solder,just re solder and should be fine
Offline Jaywoo-GTI
  • -Given: 38
« Reply #10 on: March 08, 2012, 04:28:58 pm »
As above, you will just need a very fine tip soldering iron and some solder, 2 minute job once you can get to the circuit board.
Offline Weston
« Reply #11 on: March 08, 2012, 04:31:28 pm »
Yeah I imagine getting to it would be the issue
GTI going...
Offline Jaywoo-GTI
  • -Given: 38
« Reply #12 on: March 12, 2012, 09:59:24 am »
Can anyone post some pics up of the rear of a LED cluster and i will try and do my best to help,
« Reply #13 on: March 20, 2012, 07:55:03 am »
Well mine have suddenly started working again now :smiley:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #14 on: March 21, 2012, 09:48:32 pm »
Warmer weather? sounds like condensation getting on the circuit and shorting the LED's
