Right, heres the basic wiring diagram. Im not a professional by the way, as you will probably tell!
![](https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fq739%2FBuryFan12%2F6f99fedb786fda6bd7874fef54cecf00_zps33d46cf2.jpg&hash=97ce0a6067bb10d060cd6bf27dc2f666a08ba373)
Each oem boot light needs 2 bulbs. Each bulb has a positive and a negative, therefore you have 4 wires that need turning into 2 wires for ease.
Now imagine your boot is open above you. I put one bulb on either side of the oem light. One far bulb and one closer bulb. To connect the 2 wires of negative, think of the main wire going to the closer bulb with another single wire between main wire and the bulb like so:
![](https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fq739%2FBuryFan12%2F224e8282711b031c163a3d6acc9dab23_zps1ce64909.jpg&hash=f6851e83d85993763debb3ef600400ad5e18d4c0)
To ground these lights iv used a handy little ground point on the boot lid itself, if you take all the plastics off, on the drivers side of the boot lid you will see a ground point. I just crimped a circular connector onto the end. Does that make sense so far?!
