Author Topic: Inner tail light mod units  (Read 49253 times)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Inner tail light mod units
« Reply #210 on: November 05, 2013, 07:33:54 pm »
Would thickness of the wire change anything?
hi joe tried angel eyes not bright enough but the smd rings are better but its the same problem close up look great but from a distance not as bright but i would say better than t10 bulbs down to the reflection not as good as outers with been deeper and more reflection i put the ring facing inwards so they reflect off the silver inner other wise all you see is a ring of dots from leds
Are the lights easy to split? Which angel eyes did you use? Yeah im going to put them in backwards to they reflect better too.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #211 on: November 05, 2013, 07:40:39 pm »
Get some pics too!
Offline Timvgti
« Reply #212 on: November 05, 2013, 08:37:25 pm »
Better than t10 bulbs?! Seen my movie?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #213 on: November 05, 2013, 08:40:35 pm »
Any idea what gauge wire you used? I used something quite thick
Offline Timvgti
« Reply #214 on: November 05, 2013, 08:54:58 pm »
Measured the wire I used. Outside (including shielding) is 2.35mm (0.092519685 inches) thick.
Sorry don't know how many awg that is.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #215 on: November 05, 2013, 08:58:43 pm »
Does wire thickness effect brightness?
http://www.golfmkv.com/forums/showthread.php?t=149564
This might be an option for wiring. They have tapped into the plug that goes into the main outer light
Offline biglad65
« Reply #216 on: November 05, 2013, 09:02:56 pm »
hi used these red ones so dont get that white ring round reverse lens or fog
http://www.ebay.co.uk/itm/221123431618?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #217 on: November 05, 2013, 09:05:04 pm »
And they fit in?
Offline biglad65
« Reply #218 on: November 05, 2013, 09:07:35 pm »
yes anything from 75mm inner edge to 110 outer edge
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #219 on: November 05, 2013, 09:09:45 pm »
How did you split and re-seal them?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #220 on: November 05, 2013, 09:12:44 pm »
White ring? What do you mean?
Offline biglad65
« Reply #221 on: November 05, 2013, 09:14:50 pm »
Offline biglad65
« Reply #222 on: November 05, 2013, 09:16:44 pm »
where the red lens joins the chrome round bit in middle there is a little gap that the light shines out of if not red
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #223 on: November 05, 2013, 09:19:50 pm »
Ah got you now! I wonder if putting 2 led rings in would make it brighter!  :signLOL:
Offline biglad65
« Reply #224 on: November 05, 2013, 09:26:05 pm »
one is bright enough its just the same old thing the further away you go the dimmer it becomes just will not hold the light due to the reflection situation the ones tim as done are diff to ours so i asume thats why hes are holding light
