Author Topic: Inner tail light mod units  (Read 49188 times)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Inner tail light mod units
« Reply #225 on: November 05, 2013, 09:31:00 pm »
I wonder if its possible to up the power to them using VCDS....
Offline biglad65
« Reply #226 on: November 05, 2013, 09:38:06 pm »
you can get them brighter i tryed this out with a dimmer switch to look the same from a distance but then when close up they are too bright compared to the outers its like having brake light on all time you just carnt win with it because the outers give off more reflection than inners as inners are not made for it so its a case of doing the best we can and then putting up with it  :signLOL:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #227 on: November 05, 2013, 09:39:29 pm »
Central electronics - 9
Adaptation - 10
In there you can supposedly change brightness of brakes, tail-lights and fogs. It might need a 10% increase or something
Offline Timvgti
« Reply #228 on: November 06, 2013, 02:58:26 pm »
one is bright enough its just the same old thing the further away you go the dimmer it becomes just will not hold the light due to the reflection situation the ones tim as done are diff to ours so i asume thats why hes are holding light
What is different on mine compared to Joedarka's? We both used incandescent t10 5watt bulbs?
I've connected them to the number plate lights. Because that is 12v. If you connect them to the outer lights it's 6v untill you brake, then it becomes 12v (only the outer half of that circles).
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #229 on: November 06, 2013, 05:35:34 pm »
No idea what the difference is as we used the same stuff! How much did you pain onto the tips of the bulb?
Offline biglad65
« Reply #230 on: November 06, 2013, 06:49:02 pm »
you have more room in yours so the inners are diff
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #231 on: November 06, 2013, 07:21:44 pm »
Are "normal" gti lights also more reflective?
Offline biglad65
« Reply #232 on: November 10, 2013, 01:30:17 pm »
outers yes its with them been deeper inside and more reflecters
