These are the ones I made a few months ago
Incandescent light bulb still look way better than led lights imho.
Is another name for the 501 bulbs a t10 w5w bulb? Or is this a different model?
How many clearance is there for a bulb holder?
Would this fit?:
Or this:
(possible to turn and lock?!)
diameter: 18,5mm
hole: 12,5mm
height: 15,0mm
Or use 2 or 4 smaller T5 W2W bulbs with holders?:
And is there a how-to for the wiring? Where to connect? License plate lights?
There is about 8/10mm clearance tops for the outer side, the smaller bulbs might be ok, i didnt bother to try them TBH, the 501 bulb holders you have listed will have to much sticking out the back to fit, the one with the wires out the back defo wont clear and the other ones are designed to get there live and earthfrom the metal strips inside the light so even if you could get clearance with them getting the wiring to them would be a PITA, also yes i agree LEDs do give a different glow to filaments, but once phase 2 is complete the outers will be LED'ed aswell so will look ok
Ive had mine fitted now for over a week and tbh no one has said they dont look right, a lot have asked if it was just a set model that had them fitted as there mk5 dont light up lol
yes ive got a how to for the wiring guide, the worse bit is getting the 2 wires thro the rubber boot from tailgate to car
