Author Topic: Will these fit?  (Read 1838 times)
Offline d.mellor
Will these fit?
« on: February 08, 2012, 10:17:38 pm »
As above. Looking to buy some new wheels
Fronts are, 17" 8j et 42
Rears are, 17" 9j et 42
Will these fit mk5 golf?
Offline vRS_Pagey
  • -Receive: 59
Re: Will these fit?
« Reply #1 on: February 09, 2012, 04:49:20 pm »
Providing the PCD is 112 and the centre bore is 57.1 or higher (you can fit spigot rings) then maybe, to give you an idea of the difference, the 8j wheel will extend 15mm further and the 9j 28mm than OE, so they could rub, especially the 9j.....
Offline mvb12
  • -Receive: 64
Re: Will these fit?
« Reply #2 on: February 12, 2012, 11:39:28 am »
imo 17" are too small, 18" should be standard to purchase as upgrade but each to their own i guess?
Offline Syrag64
Re: Will these fit?
« Reply #3 on: February 12, 2012, 01:23:35 pm »
IMHO even 18" looks a little small, I'm looking to get a similar size but in 19" but after looking at loads of wheels i'm thinking of going 19" 8j et 45 on the front and 19" 9j et 45 on the rear (or maybe even 19" 8.5j et 45 - if a wheel exists?)
You could also go for a stretched rear tyre to maybe minimise the rubbing?  - I could of course be wrong on that so if i am someone please correct me  :driver:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
