Author Topic: Flashing Engine Management Light  (Read 5228 times)
Offline sirwiggy
  • Here For A Good Time Not A Long Time
« on: February 09, 2012, 04:35:33 pm »
Hi all,
Got a 57 plate GTi DSG, had a flashing engine management which would go out when i slowed down. Was told it could possibly be the coil pack so i changed all 4. Happy days until driving home today and it's started again GUTTED!!!!  :sad:
Anyone got any ideas or have had the same problems?
All help greatly received.
Offline Boothy
Re: Flashing Engine Management Light
« Reply #1 on: February 09, 2012, 05:23:55 pm »
The coil packs should have been replaced/covered by the recent recall. Checked with the dealer.
Offline Weston
« Reply #2 on: February 09, 2012, 05:26:00 pm »
When were the spark plugs last changed?
GTI going...
Offline sirwiggy
« Reply #3 on: February 09, 2012, 07:12:26 pm »
The car had a major service on the 6th January 2012
My car was not on the recall list for the coil packs so VW wouldn't change them.
I had coil packs changed on tuesday this week and was hoping not to see flashing light again.
How wrong was i :signLOL:
Offline Boothy
« Reply #4 on: February 09, 2012, 07:21:49 pm »
Have a look on the Vagcom register on here and see who's local. Somebody somewhere will scan it for faults for you im sure.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: February 09, 2012, 07:33:36 pm »
this is a scan from when I fitted cruise to the car
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0020
   Revision: 5BH16---    Serial number: VWX7Z0G93NG8O6
   Coding: 040300031C070060
   Shop #: WSC 01279 785 00200
   VCID: 34631A04572070E
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -  - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100001
                    Fault Priority: 2
                    Fault Frequency: 19
                    Mileage: 32312 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:38:02
             Freeze Frame:
                    RPM: 3441 /min
                    Load: 85.1 %
                    Speed: 139.0 km/h
                    Temperature: 89.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - Intermittent - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 17
                    Mileage: 32312 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:38:02
             Freeze Frame:
                    RPM: 3434 /min
                    Load: 48.2 %
                    Speed: 139.0 km/h
                    Temperature: 90.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - Intermittent - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 13
                    Mileage: 32341 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:07:15
             Freeze Frame:
                    RPM: 4010 /min
                    Load: 40.4 %
                    Speed: 106.0 km/h
                    Temperature: 90.0°C
                    Temperature: 16.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.224 V
000772 - Cylinder 4
               P0304 - 001 - Misfire Detected - Intermittent - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Mileage: 32341 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:07:15
             Freeze Frame:
                    RPM: 3441 /min
                    Load: 85.1 %
                    Speed: 139.0 km/h
                    Temperature: 89.0°C
                    Temperature: 26.0°C
                    Voltage: 13.843 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected - Intermittent - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 13
                    Mileage: 33268 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:47:50
             Freeze Frame:
                    RPM: 3434 /min
                    Load: 48.2 %
                    Speed: 139.0 km/h
                    Temperature: 90.0°C
                    Temperature: 14.0°C
                    Voltage: 14.351 V
Readiness: 0000 0000
Cluster and Key coding
Location Great Yarmouth
Offline sirwiggy
« Reply #6 on: February 10, 2012, 06:08:34 am »
Cheers Eddie,
I've printed it off, so i'll see how i get on with that today
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: February 10, 2012, 06:34:32 am »
Use these numbers
000768
000771
000769
000772
000770
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
if you can't find one, enter it in the search box
Offline sirwiggy
« Reply #8 on: February 26, 2012, 01:36:58 pm »
Excellent news, problem now solve. It is a software issue. Now just checking to see if there is a ecu update so it can been flashed and reloaded.
Now I'm a happy GTi er :laugh:
