Author Topic: How easy to change the brakes?  (Read 1439 times)
Offline mbastow
« on: February 10, 2012, 02:17:05 pm »
How easy is it to change the discs and pads?  I've never done this myself before - is it a DIY job or do I need special tools?   I would rather do it myself if possible.  I appreciate that a lot of the guys on this forum would consider this to be a very simple task   :notworthy:
Offline higher1
Re: How easy to change the brakes?
« Reply #1 on: February 10, 2012, 02:27:26 pm »
The only real specialist tool you will need is a caliper wind back tool for the rears, you need this to wind the piston back into the caliper so theres enough room to fit the new brake pads.
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline gazbutS3
« Reply #2 on: February 10, 2012, 02:30:08 pm »
The fronts are a doddle, like Mr Higher 1 says above, you need the wind back tool for the rears. Where are you based, there may be member that can give you some guidance for beer tokens  :drinking:
Offline mbastow
« Reply #3 on: February 10, 2012, 02:36:21 pm »
How do you push the front pistons back??  Is there a thread on here including instructions on how to change the brakes?
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #4 on: February 10, 2012, 03:21:14 pm »
The task is quite easy.
BUT: You can not do ANY mistake.
So if you need to ask, DON'T do it !!
"You get what you pay for."
Offline higher1
« Reply #5 on: February 10, 2012, 03:31:41 pm »
+1
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #6 on: February 10, 2012, 03:47:26 pm »
Its a doddle changing discs/pads. But as said, if you arent capable, dont risk it.
#1493
Offline gizmo68
  • We're here for a good time, not a long time
« Reply #7 on: February 10, 2012, 05:15:59 pm »
If you have never done them before then I would suggest getting someone who has to show you the ropes.
They are not hard, but if you make a mistake then it will be costly.
What I tend to do is do one side with the owner watching what I do then get them to do the other side whilst watching over them.  :happy2:
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
Offline mbastow
« Reply #8 on: February 10, 2012, 10:01:34 pm »
THink I'm gonna get someone to do it!!  However, need to buy the discs and pads first.  Has anyone tried the standard Brembo discs and pads??
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #9 on: February 10, 2012, 11:11:58 pm »
You can't do anything wrong with Brembo other than paying more
compared to AP which are the same in a different box.
