Author Topic: Boost Leak, Symptoms?  (Read 14273 times)
Offline nezquick
« on: February 13, 2012, 09:35:00 am »
Hi, Recently my car has felt a little sluggish although not underpowered to a point that im worried about something serious.
On my boost gauge i've noticed im making about a solid 10 (or just over) peak and then it will start to drop down to about 5 psi once in the higher rev range  :sad1: Am I right in thinking I have a leak? Any advice one the best ways to check for leaks? what about using smoke? I've heard of people doing it and at work we have specially designed smoke pellets used to find leaks in plumbing and gas work could i not just hold it infront of the intake? I don't like the idea of doing it personally but if people have with success then I don't mind giving it a go.
Many thanks, I will try and get a video today and upload it so people can actually see what and how much it drops by. It feels like the higher I am in the rev range the quicker the boost drops, most noticeable in 2nd and 3rd gear.
Cheers  :drinking:
Offline gazon69
Re: Boost Leak, Symptoms?
« Reply #1 on: February 13, 2012, 04:47:35 pm »
Unplug the maf sensor, drive the car, if all feels ok you got a leak. Dont forget to plug it back in.
« Reply #2 on: February 13, 2012, 04:53:59 pm »
Worth reading this just to see if any info in it is any help to you:    http://www.mk5golfgti.co.uk/forum/index.php/topic,493.0.html
If it is any help and you're on Facebook - Please click my music page a 'Like' (as link in my signature below) - Thanks!
Offline nezquick
« Reply #3 on: February 13, 2012, 07:48:07 pm »
This is a really short and quickly put together video with my phone so sorry for sound quakity and cellotape rustling thats all i had to hand. you can see how the boost drops off as i get to the higher end of rev counter but coudnt take it to the top.
It might be me being silly but it just doesnt feel right.. Are there any main areas to check for leaks? ill try removing the maf tomuro if i get a chance at linch. do i just let it dangle or what? iv heard they are quite fragile.
thanks in advance!
Stock ecu at the moment.
« Last Edit: February 13, 2012, 07:50:31 pm by nezquick »
Offline Sie
« Reply #4 on: February 13, 2012, 07:57:14 pm »
Think he means just unplug it. Mine does the same but I havent really had chance to go for a good drive and check it out. Will keep an eye on this thread.
Sie
Fettled Laser Blue '05 GTi 5dr
« Reply #5 on: February 13, 2012, 08:10:09 pm »
I don't ever recall my boost gauge showing such a sudden and fast drop off. Can you get someone to do some logs?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=331ddcscil1g048nk3hmq65ffc&/topic,19740.0.html
« Reply #6 on: February 13, 2012, 08:16:18 pm »
Impossible to deduce anything from that video, the pulls are not long enough. If you do a 2000rpm-redline pull in 3rd what PSI does it make?
Offline gazon69
« Reply #7 on: February 13, 2012, 08:17:27 pm »
You dont need to remove the whole sensor. Just unplug the connector from the sensor and tape it to something out of the way. Take it for a drive. If all feels ok you got a leak, if not its something else and could do with some running some logs
Offline nezquick
« Reply #8 on: February 13, 2012, 08:17:37 pm »
Thats probably me taking my foot of the pedal i think, erm no no one i know well enough has vag com or other. klstar does so i might pm him and ask politly and offer a beer token. do you know whether a.boost leak or issue would show up on a scan? If the weather holds up tomurrow ill try and get it on the ramps to check the dv.
Im driving up to bristol friday night so ill try and get some more footage if need be
« Reply #9 on: February 13, 2012, 08:19:54 pm »
Proper VCDS logging is really your only most reliable way to find out what's going on.
Offline nezquick
« Reply #10 on: February 13, 2012, 08:20:09 pm »
it will drop to and just below 5psi i try and get some.more footage but roads were a little limiting and wet so will have to take some more footage on the motorway come friday. ill let you know tomuro morning what psi i make and what it drops to.
Offline nezquick
« Reply #11 on: February 13, 2012, 08:21:33 pm »
ill try that tomuro morning then and let you know if theres a difference betwwen how it feels etc.
« Reply #12 on: February 13, 2012, 08:21:52 pm »
Are you GTI or ED30? Remapped?
Offline nezquick
« Reply #13 on: February 13, 2012, 08:24:30 pm »
Gti no map yet
« Reply #14 on: February 13, 2012, 08:27:52 pm »
You need to find out what PSI the standard GTI ko3 should be holding at high RPM, that way you can see instantly if you have a boost leak
