Author Topic: Does this look right ( VW Bluetooth)  (Read 11762 times)
Offline edition_30
Re: Does this look right ( VW Bluetooth)
« Reply #15 on: February 13, 2012, 08:24:28 pm »
is car systems not original then?
Also i want armrest version rather than glove box, is there any difference?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #16 on: February 13, 2012, 08:26:37 pm »
The car systems module is genuine but the loom will be aftermarket.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #17 on: February 13, 2012, 08:28:11 pm »
VW offer an OEM kit as well for the arm rest IIRC.  The one I listed would work in the armrest but would give you just a trailing cable to put wherever you want rather than the slot type.
Car systems is a made up kit.  If you have the BT loom with the quad lock adaptor and then the car systems adaptor it will be very bulky.
Stu...
Offline edition_30
« Reply #18 on: February 13, 2012, 08:37:40 pm »
is there any difference in quality/ audio quality etc with the after market looms?
to be honest i dont really need the slot as my iphoine is in a case and if i could have a cable from the armrest area i would be happy. I do want it to look neat tho, no manual cut-outs etc..
Are there different versions of the mdi that provide different functionality?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #19 on: February 13, 2012, 08:40:22 pm »
In which case I would suggest the kit I mentioned above with an extension cable 000 051 447 which will allow you enough slack to have it exit where ever you wish in the centre console area.
Stu...
Offline edition_30
« Reply #20 on: February 13, 2012, 08:42:03 pm »
Thanks stu..
If i wanted the armrest version as im thinking it may be a nicer fit??  could i use the same extension cable too?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #21 on: February 13, 2012, 08:44:36 pm »
Yes the extension cable is just that so it will work for both types.
Stu...
Offline edition_30
« Reply #22 on: February 13, 2012, 08:46:06 pm »
Do you know the part number for the armrest kit?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #23 on: February 13, 2012, 08:51:06 pm »
5N0 035 341E is the arm rest kit but I'm not sure if it includes a wiring loom.  The other kit I know does as I've used them.
Stu...
Offline edition_30
« Reply #24 on: February 13, 2012, 08:57:16 pm »
VW should be able to tell me?
If it does not come with the loom then can this be purchased separately?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
Offline edition_30
« Reply #26 on: February 13, 2012, 09:06:18 pm »
Thanks again stu
I will speak with vw tomorrow and then go from there...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #27 on: February 13, 2012, 09:06:55 pm »
Stu...
Offline vwrascal
« Reply #28 on: February 13, 2012, 09:09:01 pm »
It would break my heart to have to give those twa@ts any money.  Have you thought about a genuine kit??
There are two options but the better one for glovebox IMHO is 5N0 057 342 at about £150 ish from your local dealer
Sorry to hijack, but can I have the glovebox mdi ipod lead with a 6cd changer  or does it share same quadlock?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #29 on: February 13, 2012, 09:09:54 pm »
I think they can co-exist.
Stu...
