Author Topic: Engine Oil Disappearing- VW say cant find a fault- advice please  (Read 5696 times)
Offline Homer
« on: February 14, 2012, 10:52:49 am »
Hi, over the past year I have topped up my engine oil on three occasions, about 5 litres in total. The car is under warranty so I have taken it to VW, they are saying they have checked it and cant find no fault and that if I want further investigation its going to cost me £67.15 as they are not sure it is a warranty issue. I am not sure what exactly to do next as engine oil shouldnt just disappear... She said one factor could be the high mileage that I am doing- about 15-20k a year. Any advice on this would be greatly appreciated. Thanks
Offline edd666999
  • -Receive: 89
Re: Engine Oil Disappearing- VW say cant find a fault- advice please
« Reply #1 on: February 14, 2012, 10:57:45 am »
1 liter every 600miles is normal as far as VW are concerned. I have put similar in as you.
Offline Homer
« Reply #2 on: February 14, 2012, 11:00:25 am »
I take it you mean 6000 miles?
Offline Russ_leeds
« Reply #3 on: February 14, 2012, 11:10:27 am »
No 600
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #4 on: February 14, 2012, 11:18:59 am »
Yep about 600-900 per litre for me :)
www.distinctdetailing.co.uk
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #5 on: February 14, 2012, 11:29:23 am »
Mine does not take oil at all if taken easy. But if I push it hard or on RR it drinks a lot.....
Offline AlanEdition30
« Reply #6 on: February 14, 2012, 11:34:38 am »
Homer when was your car last serviced? (oil change), my car hardly uses any oil, the only time it did start to use a bit was just before it was due a service.
A service sorted it  :happy2:
Though as a few others have said 1 litre per 600 miles is within the tolerances
Offline gazon69
« Reply #7 on: February 14, 2012, 11:36:03 am »
Yea sounds about right. They do have a thirst for the stuff im afraid. When they are driven hard they do use a fair bit
Offline Tamiyoman
  • -Receive: 39
« Reply #8 on: February 14, 2012, 11:45:06 am »
Drive FSI cars like miss daisy and they dont use much, push them and use the full rev range and they drink the stuff.
Had my ED30 3 months now and done around 1000 miles and its taken 1.25L of topping up thus far.
Your car is normal.
Offline swgti
  • -Given: 28
« Reply #9 on: February 14, 2012, 12:13:17 pm »
I've had mine 9 months now and it hasnt used a drop.
Going on VW's figures thats nearly a litre every other tank of fuel, If mine was using 1ltr per 600 miles based on my mileage so far and using Castrol Edge I would have spent nearly £170 in oil in that time........ :scared:
Offline Homer
« Reply #10 on: February 14, 2012, 12:16:31 pm »
last service before todays was in August, thanks for all the replies folks, best stock up on engine oil then  :happy2:
Saintsteve
« Reply #11 on: February 14, 2012, 12:20:41 pm »
my high oil consumption was partly due to a loose engine cover, oil was leaking down the back of the engine, not apparent on the floor but worth checking if you have the top engine cover off, to just try the bolts and check they are tight.
My consumption has now reduced I've noticed.
Offline Black9
  • -Given: 35
« Reply #12 on: February 14, 2012, 02:22:50 pm »
I think it varies engine to engine. Mine uses hardly any oil whatsoever but heard others use quite a bit. Keep ontop of consumption & change the grade of oil if neccesary
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #13 on: February 14, 2012, 03:48:06 pm »
Same here... mine uses about a 1litre of top up per service(8000miles)... Not like the BMW's ive had which is more like a 1litre every1-2k miles...
Diesel Daily Hack.
Offline flyboy1976
« Reply #14 on: February 14, 2012, 04:15:48 pm »
cant say the same here, 30k Edition 30 ....Stage 2+, no oil consumption since ive had it (2 1/2 years)
