Author Topic: Engine Oil Disappearing- VW say cant find a fault- advice please  (Read 5455 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=skesqpd9nimecaboa1qmppausg&/topic,19740.0.html
Re: Engine Oil Disappearing- VW say cant find a fault- advice please
« Reply #15 on: February 14, 2012, 04:23:46 pm »
5L in a year is not an astronomical amount. A Mazda RX8 would chew about 20 litres in that time (at least)
Offline heavyd
  • -Receive: 29
« Reply #16 on: February 14, 2012, 04:29:03 pm »
Its when you use half a dipstick every 200 miles like mine did, that you need to worry :scared:
Offline gazon69
« Reply #17 on: February 14, 2012, 04:33:03 pm »
:signLOL:
Saintsteve
« Reply #18 on: February 14, 2012, 05:08:02 pm »
That's about 2.5 litres every thousand miles... Still within VW's tollerences.
Are u sure you really needed a rebuild  :grin:
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #19 on: February 14, 2012, 05:28:08 pm »
Ive a litre bottle of oil I keep in the boot which I top up from a 4 litre in the house. Mine likes a drink now and then.
« Last Edit: February 14, 2012, 05:30:11 pm by parks »
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline heavyd
  • -Receive: 29
« Reply #20 on: February 14, 2012, 05:39:00 pm »
It was nearly a full top up bottle a week at the end. I used up 2 full 4ltr bottles of castrol edge in about 3 months. Didn't use a drop the first 9 months I owned it.
I haven't used a drop since its been fixed either
Offline edd666999
  • -Receive: 89
« Reply #21 on: February 14, 2012, 06:08:00 pm »
I take it you mean 6000 miles?
 :signLOL:
You would hope so! but no.
Offline martziniuk
« Reply #22 on: February 14, 2012, 08:09:23 pm »
Did you ever find out why it was using so much oil, was it rings or stem seals etc?
  • -Receive: 291
« Reply #23 on: February 14, 2012, 08:12:17 pm »
For the first 10k of its life, my car used a litre. Since then it's needed around a litre over the last 30k miles.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 247
« Reply #24 on: February 14, 2012, 08:13:04 pm »
Mine gets through about 1litre every 2000 miles.  :sad1:
Offline micky 32
« Reply #25 on: February 14, 2012, 11:25:12 pm »
Be interesting to know why some cars use oil and others don't. Mine goes from the max to min mark in 1700 ish miles.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
« Reply #26 on: February 15, 2012, 12:22:10 am »
and they say the tdi's are oil burners :signLOL:
Offline 182_blue
  • -Receive: 54
« Reply #27 on: February 15, 2012, 07:10:35 am »
I think it varies engine to engine. Mine uses hardly any oil whatsoever but heard others use quite a bit. Keep ontop of consumption & change the grade of oil if neccesary
Same here... mine uses about a 1litre of top up per service(8000miles)... Not like the BMW's ive had which is more like a 1litre every1-2k miles...
My edition 30 never needed topping up and the R is the same.
Offline edd666999
  • -Receive: 89
« Reply #28 on: February 15, 2012, 08:13:20 am »
Could be related to oil used? Journey type? Driving styles?
I know mine uses significantly more oil when i have ignored the fuel bill.
Saintsteve
« Reply #29 on: February 15, 2012, 09:18:51 am »
There's the answer from both angles. don't drive it, it won't use any, but if you are more enthusiastic with the throttle, it will use oil to some extent  :signLOL:
