Author Topic: MFD2 DVD and changing battery  (Read 863 times)
Offline surfer
« on: February 14, 2012, 08:26:03 pm »
If I have to disconnect my battery to change it will I need the code to get the stereo going?  If so where do I find the code?
Offline Squeeguk
Re: MFD2 DVD and changing battery
« Reply #1 on: February 14, 2012, 09:32:42 pm »
The code would be on a card that should have been supplied with the unit. Other than that, I think you might need to go to a main dealer to get it. Pretty sure VCDS will not be able to get the code from the unit before disconnecting.
Offline mvb12
  • -Receive: 64
« Reply #2 on: February 15, 2012, 12:34:48 pm »
if you don't have the code card you most prob will need to go to a steelers.
