Author Topic: Attention all vagcom boffins / people who can read and tell me something  (Read 4563 times)
Offline nezquick
Heres my scan and results.
Sorry I am really new to this and trying to teach myself but I don't want to be messing around with codes and possibly upsetting my car before I drive to briston on friday.
So forgetting about the electric windows (they work fine and so does my footwell lights so can't quite work it out?!)
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: ----------- Mileage: 116810km/72582miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW:
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0D1220341
   Coding: 0403000318070060
   Shop #: WSC 00607 210 71741
   VCID: E3C12BBF5BC5
2 Faults Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
               P0299 - 002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 115422 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:37:28
             Freeze Frame:
                    RPM: 3718 /min
                    Load: 84.3 %
                    Speed: 52.0 km/h
                    Temperature: 87.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.224 V
000256 - Mass Air Flow Sensor (G70): Supply Voltage
               P0100 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 5.0°C
                    Temperature: 5.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 3A7F36DB0CCF
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67D9BFAF2FFD
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001309029
   Coding: E58D0F0600041800001400001400000000087F075C
   VCID: 3A7F36DB0CCF
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 00000
1 Fault Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 08 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD0316KN
   Coding: 0012344
   Shop #: WSC 01269 785 00200
   VCID: 2C530083F69B
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000012
   VCID: 356525E725D1
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 960 D
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0003403
   Shop #: WSC 00607 067 57207
   VCID: 306B14F3DAB3
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C02079E
   Coding: 3D3F0340070003
   VCID: 295DF997F969
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
   VCID: 306B14F3DAB3
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   VCID: 306B14F3DAB3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 316D11F7D1B9
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 81C802087F2D8505485FC69010
   VCID: 7BF1F3DF4375
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0154
   Coding: 0000052
   VCID: 316D11F7D1B9
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       012 0022
   Coding: 0040402
   VCID: 2F69178FC78D
1 Fault Found:
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 306B14F3DAB3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 316D11F7D1B9
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End   ---------------------------------------------------------------------
Can someone explain to me what to do please?! THANK YOU! Should I just click the clear all faults button and hope for the best?!
Thanks so much in advance and please be nice, we have to learn from somewhere. Think of it as im the pupil and your the teacher  :wink:
Offline nezquick
Re: Attention all vagcom boffins / people who can read and tell me something
« Reply #1 on: February 15, 2012, 05:50:29 pm »
P.s I don't mean boffin in a rude way  :signLOL:
Offline kalu
« Reply #2 on: February 15, 2012, 06:17:55 pm »
Looks like you have a boost leak!
Also at some point the MAF has been disconnected.
I would start by looking at your Divertor Valve as thats the most common cause for this on TFSI's
Offline nezquick
« Reply #3 on: February 15, 2012, 06:26:57 pm »
Iv been discussing this with other people and swore iv had a boost leak for a while. millage is high so presume it has gone by now. should i just clear all codes and moniter the situation and whether they come back? Maf was discounnected three four days ago so explains that! Thanks for your help and response!!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: February 15, 2012, 07:09:23 pm »
I agree with Kalu, for the time and effort involved check the DV.
Stu...
Offline nezquick
« Reply #5 on: February 15, 2012, 07:15:10 pm »
Ok, so far I have learnt the following:
000256 mass air flow sensor can simply be cleared as it was removed causing this fault.
Electric windows because I discounnected and changed my battery (same for radio) so just need to do the reset of all he way up all the way down, 2 secods, all the way up again and can clear codes,
ABS Brakes I am unsure about but may be from when I unplugged the MAF as it does turn traction control off and apparently the DTC memory - intermittent is more of clear job so will just clear that.
The footwell light is from the LED's im using but should not be a problem once cleared the codes although it may still through an error (not too bothered)
but the main one in like mentioned the boost pressure regulation as from what I've read leads me to think it is in fact a torn dv, I think I will stop at the garage tomurrow and ask him to take a look for me as he won't charge me anything to look and the weather isn't brilliant to be lying under a car.
The main question now is if I read the codes in the morning before work and then choose the clear codes function. Is it safe to clear the boost pressure regulation code or will it make it unsafe to drive. Also will it just through up again after driving and from what im looking at (and guessing) almost 30mph at 3718 rpm?
and how long will it take roughly so I know how much earlier to wake up before I go to work.
thanks in advanced!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: February 15, 2012, 07:17:04 pm »
You can clear the codes no problem..
Stu...
Offline nezquick
« Reply #7 on: February 15, 2012, 07:19:12 pm »
 :happy2: Ill do that in the morning then, any idea how long it could take?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: February 15, 2012, 07:19:47 pm »
To reset the windows you can also use the ignition key in the drivers door lock. Turn it fully to lock and count to 2, then turn it to unlock, hold it and all the windows will open. Again count to 2 then turn the other way, hold till all windows close and count to 2.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: February 15, 2012, 07:20:52 pm »
To clear codes?  No time at all.
To check DV?  30 mins For a first time.
Stu...
Offline nezquick
« Reply #10 on: February 15, 2012, 07:28:00 pm »
lovely I think ill do that then, can I do it using the key (where you make the windows go down with unlock and up with lock when you hold the buttons down) because then I don't have to do it outside I can do it from my front room in the warm  :signLOL:
Lovely, Yeah I had a look the other day under the car anyway and could see it  the one question I have is it easier to get to the bolt at the top from above?
tool wise im sorted to do it just want to know if theres any experienced tips, for example someone told me to leave the bonnet open makes things easier to see even from under the engine.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: February 15, 2012, 08:24:50 pm »
Attack it from underneath. To be honest you may as well get a new DV and fit it as the revised models are more reliable.
Stu...
Offline af1
« Reply #12 on: February 15, 2012, 08:26:29 pm »
completely off topic but i have lost my genuine bag com lead :(
not happy
Offline 56OctyVRS
  • -Receive: 72
« Reply #13 on: February 16, 2012, 09:42:13 am »
Also dont forget to  check the pcv as that can bring on the P0299 fault code. I was plagued by this fault code a while ago and it turned out to be the stage 1 map. Since I had it updated the fault code has never appeared again.
Offline nezquick
« Reply #14 on: February 16, 2012, 10:02:57 am »
Cheers, did my windows this morning before work but decided to wait until I get home tonight before cleaning them using vagcom and clearing all codes at the same time.
I did the check where you let the engine idle and it should go rough if the pcv is failing. Sound right? if not whats other ways to check? i think i read something somewhere that you need to remove the pcv valve and try and blow through it?
no map yet so can't be down to that.  :sad1:
