Author Topic: Should my engine sound like this....(video)  (Read 3200 times)
Offline Russ_leeds
Re: Should my engine sound like this....(video)
« Reply #15 on: February 15, 2012, 10:27:39 pm »
my cambelt used to do it but no where near as bad as that and i got a new cambelt and water pump done f.o.c on warranty  :jumpmove:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Dsg steel
« Reply #16 on: February 16, 2012, 12:24:39 am »
Mines making same noise even tho I've changed cambelt kit and tensioner 20k ago.
Anyone with same problem?
Only happens when it cold
Billy
Offline Horatio
  • -Receive: 39
« Reply #17 on: February 16, 2012, 06:17:24 am »
SNAP!
Vid taken from inside the car as I was convinced it was a loose bolt. Mine has done this as well since purchased in August. Cambelt is due, just over 4 yoa on 28k.
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #18 on: February 16, 2012, 07:37:45 am »
Mine sound like that too...is it a big job to do as my cambelt is not due for another 30k
Mine needed doing at around 32k.
Saintsteve
« Reply #19 on: February 16, 2012, 08:06:02 am »
SNAP!
Try and do a sound clip outside on idle as that's difficult to make out its the same problem. Yours might be a blown pcv.
Offline flyboy1976
« Reply #20 on: February 16, 2012, 01:07:58 pm »
Yep I had that sound @19K.....warranty job at the time but I had x2 idlers, cambelt and tensioner inc waterpump all done at the same time....same as Steve said, did it from cold then shut up after a while.
Offline Creatz
  • The Noob
« Reply #21 on: February 16, 2012, 02:46:48 pm »
i made the same post last year  :signLOL:
i got the cam belt (it was nearly due)changed and now its silent  :happy2:
but nothing to worry about
  • -Given: 32
  • -Receive: 78
« Reply #22 on: February 16, 2012, 03:06:15 pm »
I too have a cambelt video!
Offline Tamiyoman
  • -Receive: 39
« Reply #23 on: February 16, 2012, 04:35:06 pm »
Same noise as mine altho mine is quieter than that, once warmed up its barely noticeable.
  • -Given: 32
  • -Receive: 78
« Reply #24 on: February 16, 2012, 06:07:59 pm »
Yeah, at first it was only audible when the engine was cold, but eventually it got to a point when it was pretty pervasive.
Offline Horatio
  • -Receive: 39
« Reply #25 on: February 28, 2012, 07:24:56 pm »
SNAP!
 :sad1: Ive sent you an email with vid attached, if you dont mind  :ashamed:
Saintsteve
« Reply #26 on: February 28, 2012, 07:37:41 pm »
No email as yet?? just looked...
Offline Horatio
  • -Receive: 39
« Reply #27 on: February 28, 2012, 07:51:23 pm »
quick off the mark!  :driver: just sent
Offline Horatio
  • -Receive: 39
« Reply #28 on: February 28, 2012, 08:35:41 pm »
Video outside, excluding the squeakyness. The rusty bolt at the centre of the video, above the belt, is making all the noise, it seems to me. WHat is it?  :confused:
