Author Topic: Cruise Control Part Number Query  (Read 3032 times)
Offline tkboyle
« on: February 16, 2012, 08:40:23 am »
I'm looking at the part numbers for cruise control but having difficulty figuring out which one is applicable to a Mk5 Golf GTi Edition 30
It's a 2007 Model with Highline and MSFW Manual Transmission.
Searches reveal two part numbers that are applicable.
1K0 953 513 G - VW GOLF 5 2004-2008 ( all versions )
1K0 054 690 A - VW Golf V 2004 > Including GTI
Which one is right?
Offline skard
  • -Receive: 245
Re: Cruise Control Part Number Query
« Reply #1 on: February 16, 2012, 08:46:56 am »
Top one is the stalk, bottom one is a retrofit kit?
You should have the wire in place on your car so you probably just need the stalk and some VCDS coding.
Offline tkboyle
« Reply #2 on: February 16, 2012, 10:52:44 am »
Both stalks look different in design.
1K0 953 513 G
1K0 054 690 A
Offline skard
  • -Receive: 245
« Reply #3 on: February 16, 2012, 11:40:43 am »
The top is just a newer design.
Both are useable, as my car came with the bottom one but I now have the upper stalk as the original was starting to fail.
Offline tkboyle
« Reply #4 on: February 16, 2012, 11:48:51 am »
That is just what I needed.
Many Thanks.
