Author Topic: Fog Lights **not wiring to the main Loom**  (Read 3086 times)
Offline zenicman9
« on: February 17, 2012, 01:00:35 pm »
Hi All
I have some fog lights and I am looking to wire them (not to the main loom) does anyone know what wires I would need?
I am going to put a button in the centre console for them any suggestions :
Offline zenicman9
Re: Fog Lights **not wiring to the main Loom**
« Reply #1 on: February 21, 2012, 10:29:21 am »
Anyone just looking to wire them to a switch
Offline bakili
« Reply #2 on: February 21, 2012, 03:42:50 pm »
I did once on my passat B5.5, bought wiring loom from Halfrauds, calls fog light wiring kit, costs around £15.
Offline zenicman9
« Reply #3 on: February 21, 2012, 03:44:39 pm »
Do you know if they still sell it?
Offline bakili
« Reply #4 on: February 21, 2012, 03:49:38 pm »
Yes I believe they do, you get relay, wiring and instruction with,it was straight forward job on passat. I believe with MKV you will need Vagcom to activate fogs after install.
Offline zenicman9
« Reply #5 on: February 21, 2012, 03:57:19 pm »
Will I need vag com even if I don't wire it to the main loom?
Offline bakili
« Reply #6 on: February 21, 2012, 04:00:38 pm »
Cant help any further bud, you might find answers on http://uk-mkivs.net, few members just did fog lights wiring on MKV
Offline skard
  • -Receive: 245
« Reply #7 on: February 21, 2012, 04:41:38 pm »
You can buy any 'spot light wiring kit' from eBay/Halfords for £10-15. It will come with wiring and probably a relay.
You just take a direct, fused feed from the battery or another thick 12v constant supply somewhere in the engine bay.
I did this years ago on a 206, can't see how you need VCDS as this should be totally independant to any control module (depending on how you wire it though).
If you Google for a guide, it will apply from any car as this is a seperate circuit you're putting in. It only gets complex when you start taking a switched live, tapping into sidelights etc.
In my old car I just had them wired direct to the battery, and used them whenever I needed but had to remember switch them off with the ignition off (battery feed = lights stay on until switched off manually). Make sure you get a switch with a neon/light indicator.
I'd also suggest you get the fog connector plugs and a few inches of wiring to solder onto as it makes a solid, watertight connection.
When I did it I ran the wiring straight into the switch which was a 205 GTI fog button, there already was a dash cutout for this anyway. This button had a relay built-in.
In my opinion, I would look into doing it properly as a retrofit. I know it'll be much more expensive but in my old car I hated the DIY way of doing it and ended up fitting it via the car wiring (process similar to a Golf).
