Author Topic: Door mirror indicator lens  (Read 4032 times)
Offline suave
  • -Given: 31
« on: February 18, 2012, 09:41:37 am »
Guys
How do I remove my door mirror indicator lens? Is it simple enough?
I need to clean it from the inside as has got a bit moss coloured.
Re: Door mirror indicator lens
« Reply #1 on: February 18, 2012, 10:29:53 am »
The mirror indicator lens is a sealed unit so if you have moss in it there'll be no way to clean it.   :sad1:
Offline Johnny_tro
« Reply #2 on: February 18, 2012, 10:33:57 am »
Correct they are sealed.
Remove the out cover of the mirror, small surround........then all the insides. Easy enough, just a pain. You have to strip the whole thing to get to the screws to remove it.
I have elec/heated mirrors so have to remove glass, all the connecting wires.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: February 18, 2012, 10:34:24 am »
Heres a guide on removing the lens, but as Bacillus says looks like you need a new unit  :happy2:
http://golfmkv.com/forums/showthread.php?t=103242&highlight=removing+side+mirror+housing
Offline Aweful_Truth
« Reply #4 on: February 18, 2012, 04:20:44 pm »
I've literally just removed my original clear indicators if you want them?
To Bad, So Sad, Bye Bye!
Offline suave
  • -Given: 31
« Reply #5 on: February 18, 2012, 06:37:10 pm »
Thanks AT
If they're sealed then the slight bit of green must just be at the outer edge?
How did you get yours out please? Do they pop from the door side? If I can get them out I can check cleaning the whole sealed unit before considering buying yours.
« Reply #6 on: February 18, 2012, 06:58:39 pm »
No worries  :smiley:  I used this guide;
Took about 20mins for the first one then like 10-15 for the other side when I knew what I was doing :) I only needed one size torx and a flat head screw drive, all explained in the guide  :happy2:
