Author Topic: Can I drive the car if I fit cruise control but don't code it in?  (Read 1186 times)
Offline Dw1
There might be a time lag between me fitting it and coding it in. Is the car safe to drive i.e. does it do everything it used to do but the cruise won't work until coded in?
Or do I need to code it in at the same time?
Offline edd666999
  • -Receive: 89
Re: Can I drive the car if I fit cruise control but don't code it in?
« Reply #1 on: February 18, 2012, 10:43:41 am »
mine was fine
« Reply #2 on: February 18, 2012, 10:44:42 am »
I would have thought it would be save to drive seeing folk normally turn off stuff using vcds as part of their tweaking.
Offline skard
  • -Receive: 245
« Reply #3 on: February 18, 2012, 10:46:05 am »
Yeh you'll be fine, it will just function as a stalk as normal.
Inicidentally, when I didn't have the car long and had a faulty engine ECU, the dealer never recoded cruise with the new ECU so it didn't work although the stalk was installed.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: February 18, 2012, 10:46:24 am »
Hi
You can fit, and drive the car.
It will log a fault which can be cleared when you get it coded.
The only issue you might have is if the steering angle sensor loses basic settings, with no vag com to start basic settings
Cluster and Key coding
Location Great Yarmouth
Offline Dw1
« Reply #5 on: February 18, 2012, 11:13:21 am »
What would cause it to lose settings and how would I know it has? Is it unsafe if it loses the angle settings?
« Reply #6 on: February 18, 2012, 01:40:17 pm »
You would get the yellow steering light illuminated in the instrument cluster.
Offline big al
« Reply #7 on: February 18, 2012, 02:34:34 pm »
I have the stalk fitted but not the wire so the cruise doesn't work. Never had any problems, just the fault code on the VCD.
