Author Topic: Just installed my RNS-510 coded but habe some errors?  (Read 8426 times)
Offline smokey
    • Club night in Bristol - Drama
« on: February 18, 2012, 12:22:08 pm »
Hey Guys
Just instslled my RNS-510 i used VCDS to code it to the car using this guide
http://www.my-gti.com/1411/volkswagen-rns-510-coding-when-installing-with-a-factory-amplifier
Did a scan afterwards and still getting the odd error
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104A230750
   Coding: 3D0F0B48070001
   Shop #: WSC 00046 000 16384
   VCID: 295DF997F969
1 Fault Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 143804 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:35:28
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H41 2720
   Revision: AB001001    Serial number: VWZ6Z7K9232194
   Coding: 000100020100008000
   Shop #: WSC 05314 000 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2E570A8BC087
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 143804 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:36:27
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 143804 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:36:31
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 2E570A8BC087
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 143804 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:36:27
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 143804 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:36:31
Any ideas? Im assuming i have missed something?
2004 GT TDI 2.0 (140bhp) - Mods so far - GTI pedals, GTI Interior Metal Strips, GTI Metal Ashtray, Gear Knob with metal surround, TPMS (with switch), RNS-510, Skoda bluetooth kit, Armrest MDI, VCDS owner (Bristol)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Just installed my RNS-510 coded but habe some errors?
« Reply #1 on: February 18, 2012, 05:19:12 pm »
disable microphone monitoring in the RNS
clear the others in the unit
make sure navigation is coded in the gateway
Cluster and Key coding
Location Great Yarmouth
Offline smokey
« Reply #2 on: February 19, 2012, 11:17:45 am »
Ok cool will turn of the microphone monitoring, I assume this is done using VCDS?
As for coding for navigation in the gateway I have selected navigation isn't that all I need to do?
I am here:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: February 19, 2012, 01:16:30 pm »
It looks to me like there is/has been a break in the CAN to the Nav.  If this doesn't clear then it will need investigation but it's possible you caused it during the install so it may clear.
Have you got anything else fitted that piggy backs the plug to the radio?
Stu...
Offline smokey
« Reply #4 on: February 19, 2012, 03:21:08 pm »
The only thing which is also plugged into the RNS is the cd autochanger cable. I haven't got the cd autochanger plugged in though as its not working so didn't bother coding it to use the cd autochanger.
One thing I did wonder was when following the coding guide it shows you how to set the factory amp up. How do I know if I have one or not?
I am here:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: February 19, 2012, 03:25:42 pm »
Do your speakers have Dynaudio badges on them?
Stu...
Offline smokey
« Reply #6 on: February 20, 2012, 01:17:30 pm »
I take it the Dynaudio badges would be on the front of the speaker grills, or do i need to take the door cards off to look behind them?
As for the soundsystem i have just selected Volkswagen Sound System ( i guess this is correct if i dont ahve Dynaudio)
Good news is i have been able to remove some of the errors, i will post up the new scan later on tonight.
Think its just something i've not or have selected
Thanks again guys (we are getting there  :happy2:)
Offline smokey
« Reply #7 on: February 20, 2012, 02:14:06 pm »
Also one other thing i've noticed is the Gala doesnt seem to be working.
I have set the SDV volume to the highest in the sound settings and have even found the SDV settings in the secret menu (not too sure what to do in that section)
whilst driving i did look at the Can option in the secret menu and my speed (in kph no mph?!) was being registered in the RNS so the can is sending the speed info to the unit.
I have read on a different forum that it could be the older can gateway that I have. I've done the fimware update to the RNS to prevent battery drain and keep my current gateway which is version E
Offline smokey
« Reply #8 on: February 21, 2012, 08:09:46 am »
Morning Guys
These are the error codes which i am left with:
   Component: RNS-MID       H41 2760
   Coding: 000100000100008000
   VCID: 2E570A8BC087
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 143860 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:53:06
   VCID: 2E570A8BC087
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 143860 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:53:06
Also going back to one of my last questions, do all VW's has some kind of amp installed?
