Author Topic: key fob battery replacement  (Read 6438 times)
Offline damoegan
« on: February 18, 2012, 05:09:40 pm »
Both of the Mrs' remote key fobs are dead, I've replaced them both but they still dont work. The LED on the fob's are working!
Do I need to re-programe them or something?
Offline Starshaped
Re: key fob battery replacement
« Reply #1 on: February 18, 2012, 06:52:57 pm »
They dont usually need recoding after battery replacement so may have another fault.
hugh jass
« Reply #2 on: February 18, 2012, 07:21:01 pm »
 have you put them in upside down :signLOL: :mad: :grin:
Offline skard
  • -Receive: 245
« Reply #3 on: February 18, 2012, 07:28:52 pm »
Try remote key matching again
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_%281K%29_Comfort_System#Coding
I had to replace the remote part of my key a few months back, just doesn't connect to the car anymore even though the LED works. Ended up getting another remote from Ed which worked perfectly.
Offline apples12
« Reply #4 on: February 18, 2012, 09:29:08 pm »
will need 'recoding' again if you took longer than 40seconds to change the battery... was told this by the vw tech at birmingham vw...
but to recode its a piece of cake...
get in your car, lock the door using the button the drivers door, insert the key into the ignition, turn the ignition on (lights only) press the unlock button, wait 6 seconds, keep pressing the unlock button, eventually you should hear it unlock the doors.
this has worked for me twice now on two different mk5's! good luck  :happy2:
MK6 GT TDI  - CW - LUX pack
GONE
